Sewing Machines Logo
Kate Hall Posted on Aug 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The top thread won't pull the bobbin thread up. It's threaded properly and the bobbin is in properly. It's an euro pro 464xc also.
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Aug 07, 2016
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613441
Points
59176
If you have installed a brand new needle and are still having issues, then it is likely that the needle/hook timing is off, ie the needle arrives at the incorrect time/place to intercept the thread.
There are multiple web sites & videos explaining sewing machine timing if you wish to try to resolve the issue yourself. Otherwise, take it for service.
How do you thread a euro pro 382?
Here are the steps to thread a Euro-Pro 382 sewing machine:
  1. Raise the presser foot lever to release the tension discs.
  2. Place the thread spool on the spool pin and slide it to the right until it clicks into place.
  3. Pull the thread end from the spool and insert it through the thread guide located at the top of the machine.
  4. Pull the thread down through the tension discs, then wrap it around the bobbin winding tension disc located on the top left of the machine.
  5. Insert the thread end through one of the holes on the bobbin and push the bobbin onto the bobbin winding spindle.
  6. Push the bobbin winding spindle to the right to engage the winding mechanism. Hold the thread end and press the foot pedal to start winding the bobbin.
  7. When the bobbin is full, cut the thread and push the bobbin winding spindle back to the left.
  8. Remove the bobbin from the spindle and place it into the bobbin case.
  9. Hold the thread end and turn the handwheel towards you to raise the needle to its highest position.
  10. Pull the thread from the bobbin case and insert it through the thread guide located above the needle.
  11. Thread the needle from front to back and pull the thread out about 6 inches.
  12. Lower the presser foot lever to engage the tension discs and pull the thread towards the back of the machine.
  13. Hold the thread end and turn the handwheel towards you to take up the bobbin thread.
  14. Close the bobbin cover and you're ready to start sewing.
How do I fix timing issues on my machine?
You can take to near Sewing machine an related repair shop an fix it within minutes...
The lower thread on this machine continues to bunch up, no matter what we try.
Please check whether it is the bobbin thread or the top thread that is messing up. If it's under the fabric, it is 99% the top thread and is called bird nesting or thread nesting.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Also check that the bobbin is loaded and turning the correct direction in the bobbin case.
Now, retest the machine.
You may need to tweak the tension to get it where it looks best.
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Install bobbin in euro-pro X 464XC
Either your machine was not threaded with the presser foot wasn't up when you threaded the upper thread... or your upper tension isn't tight enough.
Good luck.
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Lower bobbin looping
The top thread is loose and the bobbin thread is pulling the top thread down
Always thread the machine with the presser foot up and see if this eliminates the problem.
Sounds opposite of the problem, but it is very important to do this to assure the tension control can keep the top thread at the correct tension to form a proper stitch.
If the machine is threaded with the presser foot down, the tension control is closed and the thread cannot seat into the control as it should.
1helpful
My europro 464xc sewing machine sews fine with normal thread. Once I switch to thread for outdoor fabric the underneath side of the fabric looks like a rats nest. I have gone through one spool of thread...
Home use machines have a very difficult time with heavier thread, you are OK with size 50 and the larger size 40, but not with anything thicker. You can maybe get away with your thread by turning the upper tension higher, try it with the tension at 7 or 8 or 9, it "may" give you better results.
Just a note of warning, that thread may jam the machine and break your gears or your bobbin case.
2helpful
Zigzag stitch pulling tight, looks wrong
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
How to oil euro-pro 373?
Have you tried flipping the bobbin in it's case, so that the thread comes off the top of the bobbin instead of the bottom. Some machines are sensitive to one direction of the bobbin thread.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
