Question about Whirlpool AWM8163 Front Load Washer
Clean pump light comes on but cannot locate it, have cleaned the filter but still not working AWOD4305
  • 82 Answers
The filter is part of the pump right at the front of the machine.
Maybe the pipe waste is blocked?
jb
Posted on Aug 27, 2009
A red light has come on to tell me to clean the pump, how do i do this
Normally the filter is located bottom R/h side of machine this unsrews to clean the pump use some old towels for the floor as some water will come out/check pump blades as far as the Eye can see ...Good luck
Apr 06, 2011 | Whirlpool Washing Machines
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 13, 2010 | Whirlpool Washing Machines
Whirlpool awz3518 'Clean Filter' light is flashing
It would appear that this issue is related to a cold location, or the arctic air coming in through the vent hose.Sort of defeats the purpose of a dryer not working when its cold.
Dec 23, 2009 | Whirlpool Dryers
My washing machine is aWhirlpool AWOD5526. The button saying 'clean pump' keeps coming on what do I do?
Your pump is located behind the access panel at the front bottom of washer. Remove pannel and remove pump cover filter. Be prepaid for water to come out. Clean out filter and replace.
Oct 27, 2009 | Washing Machines
Ariston ventless dryer- "Clean Filter" light won't turn off, so dryer won't start
I had this same problem. The dryer would turn on for a few seconds and I could hear the water pump working followed by the "clean filter" light. This dryer has a float sensor which detects whether the pump is successfully getting rid of the condensed water. The only problem is that lint and other particulates condense out in the water and over time the float sensor gets stuck in the up position. The Ariston call center explained that the float sensor can trip the "Clean Filter" light.
In any case, the float sensor is located in the back of the dryer where the pump outlet tube comes out (when facing the back, it is in the lower right). I had to take apart quite a bit of the dryer to get access to the sensor. I ended up taking the near side off to release the plastic snaps that hold the cover over the sensor.
To fix the sensor, all I had to do was clean out the "bath" that the sensor floats in. And then figure out how to put it all back together.
Oct 06, 2009 | Ariston Technologies ASL75CXSNA 24"...
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Macine has stopped working...''clean pump'' light has come on
Remove the bottom panel, 3 screws. Drop the panel down. The pump will be in front of you.
Twist to the left and remove the filter, clean it and replace it.
Mar 18, 2009 | Whirlpool Washing Machines
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Our simpson 100 enviro won't drain. We think we need to clean the filter, but we can't remove the filter from the machine. How can we do this?
front loader filters are at the bottom use a screwdriver to remove it may be stuck full of coins.also make sure you dont have a button pressed in by mistake.hope this helps you
Mar 09, 2008 | Washing Machines
Whirlpool AWM8163 Front Load Washer Logo
170 people viewed this question
Dan Webster
Dan Webster
Sal De
