Cant get 6711a20012m to heat - Heating & Cooling
Defrorstores stay on ,try to change to floor, ac, heat vent ,deforstores still on 1995 thunderbird lx blower motor works great.
Some cars use vacuum from the engine to open and close the doors that direct the air to different positions. It is possible that the vacuum line to the controls is cracked or disconnected.
Apr 29, 2015 | 1995 Ford Thunderbird
The mode button on my kelvinator remote 6711A20012M is not working and won't change to heat yet all other buttons are working on the remote pls help???
try resetting the remote the rest switch is under the flip cover of the front of the remote use a tooth pick or something that will fit if that dose not work reset the air con by turning isolator or circuit breaker or mains breaker of for ten sec if still not working you may have to replace your remote with a universal remote can be purchased on eBay or refrigeration suppler near you good luck let me know how you go
Jul 15, 2014 | Heating & Cooling
Replace thermostat
id have to say thermostat cause water cant flow there if its stuck closed there for cant get to the heater core... but them cars are also known for intake an head gaskets all 3 things i described will heat up but no heat
Aug 22, 2013 | 2002 Buick LeSabre
Cant see odometer reading on dash and cant see when adjusting heat on screen and drivin seat doesnt heat up checked fuses and everything was good whatelse can the problem be
the odometer is a LED readout and it is burned out, this is a very common complaint, u can pull the speedo out and have it fixed for around $150
as far as the seat goes the most common problem is the heating element in the seat is shorted, you will need to replace the seats heating element
Oct 16, 2009 | 1998 Buick Regal
Cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Jul 05, 2009 | Heating & Cooling
Dont have heat air ,only cool air,cant you tell
either the element is out, lint in the duct work, or the thermal fuse is out. Clean out the duct and vent, ch eck the element and fuse for continuity with a ohms meter.
Jul 01, 2009 | Dryers
Dodge ram 99 4wd cv bolt cant remove
A lot of heat (glowing if possible), and heavy air impact. I've never been able to break one without air impact, and sometimes have had to use a lot of heat as well.
Jun 03, 2009 | 1999 Dodge Ram
Cant break the pressure line lose
Try heat....this will allow the fitting to expand, and make it easier to loosen. A small propane torch should give you enough heat.
Apr 29, 2009 | 2004 Hyundai Elantra
Heated seats not working
This is the problem with the thermo stat which is inside the seated is defective you need to get it checked and replace it.................
May 25, 2008 | 1996 Jeep Grand Cherokee
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
