Question about Zalman Tech (CNPS7700CU) CPU Fan
Cpu fan i had a desktop computer...last two days ago there's a problem postedwith black screen before the booting of my pc or windows...it says,CPUfan not detected....there's a choice there that if i press F1,windowswill boot... thats why i can use it now,my problem is,why my computerposting that my CPU is fun was not detected even though its ruuning of functioning after iboot my computer..? tell me how to troubleshoot my pc..thanks a lot... my pc desktop is brand new..
  • 44 Answers
There are usually more than one place to plug in a CPU fan. Only one of them is actually for the CPU fan, and monitored by the system BIOS. Make sure your fan is plugged into the right connector.
Posted on Jul 19, 2009
Asus g73jw black screen on boot up
That sounds like the GPU is cooked. The CPU is heating up trying to drive the GPU that is not responding.
Feb 13, 2014 | ASUS G73JW-XA1 17.3-Inch Gaming Laptop -...
My acer desktop computer screen is black, the power says it is on but no pic, keeps cutting off, tried to back up and restore, cut off, says problem with windows and it shut off as well, HELP!
  • When the computer will not boot up, it sound like it is booting as the CPU fan is running and the lights are on. It also finds the CD ROM but it won't boot from a CD either.
  • Sometimes when you have a computer black screen on startup and the power switch light will be green and then turns to orange or amber. Everything is running.
  • Everything seems to be running but you can't see anything on the screen, not even a flashing cursor. Your black screen in Windows has occurred before the Windows logo screen:
  • 1- adapter or video card
  • 2-RAM
  • 3-and Black screen on startup with an amber flashing light
  • Not enough power getting to the motherboard.
  • A dead power supply.
  • A bent pin or shorted out USB port causing a problem.
Apr 09, 2013 | Acer AX1430-UD30P Desktop Computer With...
Power light on back of Inspiron 518 is on but computer will not start by pushing start button on front panel.
Things to check !..
1st check the CPU fan to be functional cause its failure will lead to this behavior .
2nd check the ram memory ...If it has issues with the ram memory it may not boot at all ..or try to boot but only the fan will start and will make some warning beeps and go in a starting loop ..
3rd is a CPU failure..In this case the computer may start or not ..and in case it starts only the CPU will spin ..but nothing on screen .
In the last case check the wires from the source to the board ...the plugs to be well inserted and the source itself ..(measure ti with something ..or use it in another computer to see if ti is functional ..
Please rate my answer if it helps..have a good day !
Sep 19, 2011 | Dell Inspiron 518 Desktop Computer
My compaq computer wont turn on for more than a second. It boots and the cpu fan starts but than the monitor doesnt show anything even though its on, the fan turns off and the computer stops booting. I...
1) Is this a laptop or a desktop?
2) What OS are you running?
3) When was the last time that it booted successfully? Did anything change then? Did you upgrade the OS? Did you upgrade the software (firmware) on the processor (Intel or AMD)?
4) Do you see anything on the screen? Compaq logo? Boot options?
Feb 01, 2018 | HP Compaq Presario SR1500NX (PX786AA) PC...
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
My computer wont start
Does it have power coming in to your CPU? If none try to check the fuse at the back of the cPU on the power supply side.
Nov 09, 2009 | Gateway GT5220 PC Desktop
Cpu fan
It isn't detecting your fan as the fan may be dead or the sensor is dead. Both are not repairable but cheaply replaced and fixed with a new fan. The cost of the replacement cpu fan is not that much compared to a cpu. So don't try to make it last a bit longer by hitting the f1 to continue. That will catch up with you pretty quick.
If you want to double check you need to look at either the cmos setup section of a system monitoring software and check to see cpu fan speed and cpu temps. You may not see the speed but you should see the temps. If the temp is getting over 55-60 or more shut down and go get the fan. It's dead. If you see the rpms showing then you might have a motherboard problem.
However I would say you have a dead fan. Replacements are $5-15 and you need to just crack the case and pull the old one and put in the new one. You can take it to a tech but they will charge you to check it out again and then ti replace the fan and some shops will insist on new heat sink etc (those don't ever ever wear out or go bad at all)
Jul 18, 2009 | Porter Cable 75182 Variable Speed Router...
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Problem with the CPU cooling fan...!! :-(
Dear ARGHYA,
welll i can understand this, for this you can apply the Heatsink Grease between CPU and CPUFAN . it will help to reduce the CPU Temprature.
Cheerup
Mar 04, 2008 | Computers & Internet
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Zalman Tech (CNPS7700CU) CPU Fan Logo
90 people viewed this question
Top Zalman Tech Computers & Internet Experts
David Payne
David Payne
Are you a Zalman Tech Computer and Internet Expert? Answer questions, earn points and help others
