Question about Samsung J700 Cellular Phone
How can i remove the time and date on the screen? because its blocking my wall paper..
  • 217 Answers
Just go to settings,time and date and put it in hide mode.thats all...
Posted on Jul 18, 2009
How do I remove wall paper
wet it down and use a blow dryer or a heat gun works to.
Dec 11, 2014 | Victoria Home Decor Mural Art Wall Paper...
Can not get paper to shred
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 26, 2013 | Omnitech Office Equipment & Supplies
I jammed it with too much paper
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
How do I reset my Intermatic wall switch timer?
If CR2 battery went dead or if battery removed more than 1 minute, then time-date disappeared, but programming stays in timer indefinitely even if power is off.
To reset time-date. (From Section 5 in manual)
Press MODE until screen displays SET UP
> Press ON-OFF until HOUR shows ... use + key to change hour
> Press ON-OFF until MINute shows ... use + key to change minute
> Repeat same sequence for Year, Month, Day
> Press ON-OFF until DST daylight savings time ... use + key ... choose AUTO if area has DST ... choose MANual if areas does not have DST
> Press MODE to exit and save settings
Other programming steps are long.
Manual shows programming steps:
http://waterheatertimer.org/Intermatic-st01c.pdf
Walk through programming steps:
http://waterheatertimer.org/ST01C-program.html
Sep 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Printer on button keeps flashing. How do I shut down to restart? Printer screen keeps flashing as well. Says to shut off to avoid damage.
Just unplug it from the wall. Then open the flap and look for what might have caused the warning - usually it's paper block - and remove it.
Jul 30, 2010 | HP Photosmart C6180 All-In-One InkJet...
Screen saver problem..........
its very simple ...
just save it in phone memory...
more over go to www.nokia.com/asia so that u can see more wall paper &screen saver of ur compactabilty...
thank u
Oct 22, 2008 | Nokia N72 Cellular Phone
Set time & date on Cannon P100-DH II
Press the Date and Time button, when you see the date on the display screen, then press = and hold, you will see the first number blinking, then just type in the numbers (day - month - year) it moves along as you type, when you are done, press = for 1 sec the date is now set. Now to set the time press the Date and Time button again, you will see the time showing on the display, press and hold = until the firs number starts blinking, then proceed to type in the time, when you are done, press = for 1 sec the numbers are supposed to stop blinking. the date and time is set, then clear your screen (press CE/C) the date and time are saved.
Feb 19, 2008 | Office Equipment & Supplies
Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
Sumthing on the screen
Your phone has a built-in RSS-reader, its trying to tell you something about a new feed or something. You can find it under Messages.
Sep 28, 2007 | Sony Ericsson Walkman® W880i Cellular...
Samsung J700 Cellular Phone Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
