Question about Campbell Hausfeld Wall Mountable Air Compressor - FP2004
Trouble starting and sparks - Campbell Hausfeld Wall Mountable Air Compressor - FP2004
  • 118 Answers
More information needed.
Posted on Jul 20, 2009
I replaced my positive battey cable but im still having trouble starting it. what could be the problem if i replaced the positive cable?
Were you having this problem before you changed the cable?
If it cranks good but won't start, have a helper crank it, while you visually check for spark at the spark plugs, if spark everywhere, use a gage and check fuel pressure. Also, check for fuel injector pulse.
Can you check for applicable trouble codes?
Nov 30, 2015 | 1997 Ford Explorer AWD
Won't start
Check if there is spark, eventually replace spark plugs.
Check air intake and air filter.
Check fuel filter and check that the fuel pump is fine, that there is pressure and pump is not noisy.
Sep 30, 2008 | 1989 Honda Prelude
Haveing trouble starting sometimes
hi dear,
if you having trouble in starting you must check:
1.air filter
2.gasoline filter
3.Spark plugs
4.Spark plugs coils
5.gasoline pump
6.vacuum pipe
????? ?? ?? ???? ??? ???? ???? ?? ????? ???? ??? ?? ???? ???????. ????? bnzyn ??????? ??: ???????
Nov 15, 2015 | 2006 Chevrolet Chevrolet Cobalt LS
Why won't it start?
Is there spark at the coil or coils to an through the spark plug wires .Is there fuel pressure ? Does the engine have compression ? Do you know what these thing's are ? You can go to youtube an find trouble shooting videos ! Type in cranks no start ! Look at Eric the car guy , scanner danner videos . Why did you replace the cam sensor ? did your vehicle have a DTC - diagnostic trouble code ?
Sep 08, 2015 | Cars & Trucks
I have a 2005 Nissan Sentra 1.8L Special Edition and I'm having trouble starting the car. The check engine light came up and got a troubled code P0300. I have recently changed the spark plug, MAF sensor...
DTC P0300: Random multiple misfire detected. Probable cause:
1, Vacuum leaks. Damaged hoses or incorrect routing
2. Fuel contamination
3. Ignition system problem. Check ignition module, coil, spark plugs and wires
4. Fuel system problem
Oct 07, 2014 | Cars & Trucks
Having trouble starting my 1995 Jeep Grand Cherokee. Changed out distributor cap, rotor, module and spark ignitor coil and no luck. Checked for spark by taking loose a spark plug wire and using a sc
is the check engine light on. it sounds like a bad sensor crankshaft positioning sensor or camshaft positioning sensor will cause it not to start.
Aug 16, 2014 | Jeep Grand Cherokee Cars & Trucks
Will not start but turns over
Fuel or spark plug trouble could be a cause for an engine not starting. Check for spark plug spark. Remove spark plug wire and see if the wire makes a spark on engine when spark plug wire is energized. Do not tounch engine or come in contact so that you are shocked when testing for spark plug action. Check fuel pump to see if fuel is being supplied. Disconnect fuel line and place the fuel line inside a container to capture fuel. Do not cause a fire from loss of control of fuel line during trouble shooting.
Jun 19, 2014 | 1998 Ford Ranger SuperCab
Campbell Hausfeld Wall Mountable Air Compressor - FP2004 Logo
59 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
