Question about Sony Handycam CCD-TRV59E Camcorder
How do i connect thru television,i have the yellow white and red wires from the camcorder into the side of the tele but cant get the picture and sound on
    Problem Solver:
  • 19 Answers
Go into the tv menu and choose the input in the menu you are plugging into. it will be aux 1 or 2 or smething like that. you have to switch the tv input to the proper jacks in the menu
Posted on Jul 18, 2009
Dvd plays in black only
Be sure dvd player is correctly connected. If you connect the yellow video composite out the dvdto the input on the tv that is not yellow you are probably trying to watch it thru the component in . The component in is 3 wires green blue and red. if all three are not connected the picture will have no color. If you have 3 wire connection on dvd connect it to 3 wire in on tv the other red and white are audio.
Mar 15, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
I have successfully recorded from camcorder on to disc on my Samsung SH893M machine. But can you please tell me how to record from video tape to a dvd disc.
you need to connect your wire to VCR out put and connect the other side to DVD input don't forget yellow to yellow, red to red and white to white if you have 3 prongs wire.
Jun 07, 2011 | Samsung Televison & Video
What cable do i need to go from the tele to the amplifier as i have just bought 1 and the above cable is missing please
It depends which type of connections are available on the television you are using and what type of connection the receiver uses.
There are RCA connections (red, white for sound; yellow for video), HDMI is an all in one cable, or a hi def component connection which are blue, green, yellow, red and white.....
Hope this helps.
Mar 24, 2011 | Audio Players & Recorders
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Philips 32'' LCD, when I hook a DVD it plays in black and white. It will play in color in side connecter only. Please help
The side connectors are usually composite connectors meaning the have a Yellow-video Red-right audio and White-left audio connectors. Now when you are connecting them to the back and you connect the Yellow wire from the DVD player to a component input which have Green,Blue and Red connectors to the green connector, you will get a picture, but it will be in black and white. Please take moment to rate my answer. Thanks...
Nov 22, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I connected my Philips DVDR 3576H to my Sony Bravia TV and it looks like connection doesn't work. I used cables provided by Philips but I can not get access to this empty channel, on which I could get the...
The source is E1, unless you are trying to display something froma camcorder or security cam.
Philips does not provide enough cables with this product - they only provide you one set with which to PLAY a movie. You will need another red, white and yellow cable with which to RECORD. If you have a cable/satellite box, connect a 2nd red, white and yellow cord from cable box OUT to Philips AV IN. Switch the SOURCE on the Philips remote to E1, and your TV to whichever source you have the original red, white and yellow plugged into. You should get picture, and be able to record now.
Jun 20, 2008 | Philips Televison & Video
No picture
sounds like an audio/video connection problem. If you have a cable or satellite box connected with rca wires (yellow, red, white), check that the yellow wire which gives you picture is connected. the red and white are for sound.
May 22, 2008 | Hitachi Televison & Video
No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
Aug 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony Handycam CCD-TRV59E Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
