Hi, I'm looking for a manual for Oasis oil heater so I know how to use the timer. Thanks.
  • 2,355 Answers
Try manualsonline.com
Posted on Jul 24, 2015
    Problem Solver:
  • 18 Answers
Write model and serial# go on net and look for authorized distributor might even be able to google manuf---and print one out good luck
Posted on Jul 19, 2009
  • Anonymous Jul 24, 2015
    i have exactly the same enquiry??
Lost instruction manual to set timer on oasis dundee 6 station sprinkler system
I can't locate any info on that timer. There is no timer that I can't figure out, I'm an irrigation contractor. Tell me what the face looks like or what buttons or dials are on it and I'll see if I can help.
Gary
Mar 11, 2011 | Garden
Freezer defrost problem
Manual accorting to the help page of the amana manual . The defrost time is usually located under the unit close to the compressor. Often you can see the clock part go around through a hole in the cover.  I am betign that the defrost time is you problem.  If you can't here it or see it moving (the clock part that operates the cams) then it is defective. I have disassembles , cleaned and oiled defrost times in the past and have had good success restoring their function.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ARB2257CC&siteCd=AMA#owners_manuals
Nov 20, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
