Question about Porter Cable 75182 Variable Speed Router Motor
Cpu fan i had a desktop computer...last two days ago there's a problem posted with black screen before the booting of my pc or windows...it says,CPU fan not detected....there's a choice there that if i press F1,windows will boot... thats why i can use it now,my problem is,why my computer posting that my CPU fun was not detected even though its ruuning of functioning after i boot my computer..? tell me how to troubleshoot my pc..thanks a lot...
  • 1,606 Answers
It isn't detecting your fan as the fan may be dead or the sensor is dead. Both are not repairable but cheaply replaced and fixed with a new fan. The cost of the replacement cpu fan is not that much compared to a cpu. So don't try to make it last a bit longer by hitting the f1 to continue. That will catch up with you pretty quick.
If you want to double check you need to look at either the cmos setup section of a system monitoring software and check to see cpu fan speed and cpu temps. You may not see the speed but you should see the temps. If the temp is getting over 55-60 or more shut down and go get the fan. It's dead. If you see the rpms showing then you might have a motherboard problem.
However I would say you have a dead fan. Replacements are $5-15 and you need to just crack the case and pull the old one and put in the new one. You can take it to a tech but they will charge you to check it out again and then ti replace the fan and some shops will insist on new heat sink etc (those don't ever ever wear out or go bad at all)
Posted on Jul 18, 2009
  • 76 Answers
Hi
Recheck the wires connector of the cpu to the motherbord.
If connectors are plugged ok and still having problem consider replacing the fan with new one .
somtimes even when the fan is turnning it is not fast enough to get the cpu cooled.
there are some free wares that can hlp you monitor thr cpu and the cpu fan performance, I'm using speedfan.
hope it helps
    Problem Solver:
  • 19 Answers
The fan needs to be repalced
Asus g73jw black screen on boot up
That sounds like the GPU is cooked. The CPU is heating up trying to drive the GPU that is not responding.
Feb 13, 2014 | ASUS G73JW-XA1 17.3-Inch Gaming Laptop -...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
Power light on back of Inspiron 518 is on but computer will not start by pushing start button on front panel.
Things to check !..
1st check the CPU fan to be functional cause its failure will lead to this behavior .
2nd check the ram memory ...If it has issues with the ram memory it may not boot at all ..or try to boot but only the fan will start and will make some warning beeps and go in a starting loop ..
3rd is a CPU failure..In this case the computer may start or not ..and in case it starts only the CPU will spin ..but nothing on screen .
In the last case check the wires from the source to the board ...the plugs to be well inserted and the source itself ..(measure ti with something ..or use it in another computer to see if ti is functional ..
Please rate my answer if it helps..have a good day !
Sep 19, 2011 | Dell Inspiron 518 Desktop Computer
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
My computer wont start
Does it have power coming in to your CPU? If none try to check the fuse at the back of the cPU on the power supply side.
Nov 09, 2009 | Gateway GT5220 PC Desktop
My sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Sep 16, 2009 | Sony VAIO VGC-RB40 PC Desktop
Cpu fan
There are usually more than one place to plug in a CPU fan. Only one of them is actually for the CPU fan, and monitored by the system BIOS. Make sure your fan is plugged into the right connector.
Jul 18, 2009 | Zalman Tech (CNPS7700CU) CPU Fan
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Porter Cable 75182 Variable Speed Router Motor Logo
93 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
