Question about Nokia N73 Cellular Phone
At the right hand corner below the signals an arrow with a small box is in display. what is that?
    President:
  • 2,004 Answers
This simply indicates that there is an error message in your message outbo.
It can be erased only if the message is being sent or deleted.
Consider seeing to it now.
Cheers.
Posted on Jul 18, 2009
1998 jeep grand cherokee laredo turn signals quit working but the hazard lights work
try fuses, first, for 10cents.
first know how it works.
then diagnose it.
saves $$$$
1998 last year of ZJ jeeps.
FSM book, open to chapter 8w.
go to page on ext. lamps turn/haz
page 52 (ive posted the free book 100s of times, no more)
haz ok, truns dead on 4 corners
does the cluster flash when turns dead? on corners 4.??>?>?>
the 2 fuses are F13 and F6 in the JB (cab box = JB)
the cluster has 2 lamps, left and right.
if cluster is dead, that is a bad switch
this is how it works.
can be a bad connection at (see small arrow red/)/?
May 28, 2016 | Jeep Cars & Trucks
How can I change to setchannel search auto or man on a westinghouse tv mod ltv20v2sl?thankyou
Since the LTV20V2SL only has an NTSC (analog tuner), you may need a set top box to receive any stations. If you have analog cable or are close to a low-power station that still broadcasts an analog signal, you need to follow the steps below.
First, make sure that the input is set to TV. On the remote, there is a TV button in the second row of buttons below the arrow keys. It's on the left below the MTS button. You could also use the TV/Video button on the top of the TV. It's the right-most button and each press of the button will move through the entire list of available inputs. You can use the original remote to select your signal type with the TV/CATV (Over-the-air or different types of cable TV) button. It's on the right hand side of the row with the TV button. Next press CH. Scan on the remote. It's the second button from the right above the arrow keys.
Alternatively, you can use the on-screen menu. Press the Menu button on the remote (on the left above the arrow keys) or TV (the left-most button). Then use the left/right arrows to navigate to the TV sub-menu. Use the up/down arrows to select the appropriate line. First, set the second line to the correct Input signal with the left/right arrows and press Enter to confirm your choice. Then go down a line and press the right arrow key to start the Auto Scan. Note the Channel up/down arrows are up/down and the Volume up/down are left/right if you use the TV buttons.
I hope this helps.
(If you are using a set-top box, you will need to do the channel scan for that device.)
Feb 19, 2016 | Westinghouse Televison & Video
Google maps: street views keep going to a split screen with street on top and satellite on bottom. Also street views in full screen mode disappear after a second and the split screen mode reappears.Very...
When you go into the split screen, and you don't want to be there, just click the little arrow in the lower right hand corner (the arrow pointing down and to the right). This will reduce the bottom map portion into a small overview box in the lower right portion of the screen. It only takes a second to get out of the split screen that way. To get back into split screen, click the arrow in the upper left corner of the overview box (the arrow pointing up and to the right).
Aug 15, 2011 | Computers & Internet
When booting up, the monitor status splash shows up. Then it goes into a black screen with some small white boxes in upper left-hand corner. It takes forever to display the log-in screen, probably more...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Please leave a vote if you like my answer
Apr 03, 2011 | Computers & Internet
Audio display flashes in and out in the upper right corner
This usually happens when you are connecting a cable box or satellite tv box to the television with a coaxial cable. In order to get this to stop you have to connect the cable box or satellite tv box to the television with an RCA/composite cable. Then you will have to change inputs to the appropriate one with the input button on the television (press it repeatedly) or with the input button on the Sharp remote (press is and then scroll down with the down arrow and press enter).
If you are not using a cable box or satellite tv receiver you can try connecting a signal booster to your coaxial cable but that is not guaranteed to work.
Jul 13, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
Remove number displayed in right hand corner in output 4
The problem was with the cable box and not the television. We unplugged box - (we'd reset it before) and the "2" was gone.
Dec 21, 2008 | Pioneer PureVision PDP-5050HD 50 in....
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
