We just purchased this Bosch front loader washing machine and found that it was leaking badly from the front door and dispenser tray. So much so that we had to put a towel down on the floor. Thankfully, we were given a replacement machine, only to find that it too leaks. We are left with a 20cm patch of water that runs under the machine to the wall. We don't believe that it should leak at all. We would appreciate an explanation and satisfactory solution.
  • krichards13 Jul 18, 2009
    The leak is not from the hose. It is from the bottom of the door. Seems to happen during the rinse phase and spin cycle.
  • 3,230 Answers
First of all i like to know the model number of your washer.
Well, Problem seems in the - Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it.
Good Luck!!
Thanks
Posted on Jul 18, 2009
  • Mukesh Kumar Jul 18, 2009
    Ok,
    Then check the - Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center.
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Water leak from bottom of machine
This video will show you how to change a door seal on this Bosch Classixx WVF 240S front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Feb 18, 2012 | Bosch Classixx WVF 240S Front Load Washer...
Bosch WFF2001. Works OK in wash cycle but leaks heavily (from drum seal?) on rinse. Not from door seal. Any ideas?
This video will show you how to change a door seal on this Bosch WFF2001 front loader washing machine
May 02, 2011 | Washing Machines
How do I clean the mould in the rubber door seal of a Bosch front loader.
This video will show you how to change a door seal on this Bosch front loader washing machine
Apr 01, 2011 | Bosch Washing Machines
The softner tray on my front loader Maxx Clasic BOSCH does not drain - it fills with water which, together with softener, remains in the tray. Heeeeelp!
Hello, W/D here.
Remove the tray, and clean the tubes on the bottom side of the dispensers and the mating tubes on the machine. This should put you right.
Best regards, --W/D--
Feb 24, 2011 | Bosch Washing Machines
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
Bosch logixx 1600 exoress from leaking underneath approx middle
May 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Leaking door on front loader bosch washer
Make sure latch mechanism is tight and check out the seal for imperfectionc ....ie cracks or flat spots
Jul 22, 2017 | Bosch Washing Machines
Open Questions:
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
