I need the black plastic cover with nylon mesh over it. My speakers are fine but they need the front covers!
    Problem Solver:
  • 18 Answers
You can usually get replacements from the manufacturer depending on the units age. If they are molded grills that are specific to that speaker only you can also try THE PARTS STORE online. You can type in the make and model of your stereo and possibly get parts there. If they are just square grills....Parts Express sells adjustable frame kits that may work or Foam covers that are held on with velcro. The last resort is ebay. Many sellers part out speaker parts and may even have another complete unit cheap with covers.
Posted on Jul 24, 2009
HBS-750. Why is volume low?
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
Apr 14, 2014 | LG Radio Communications
Trying to undo the cord thing and it just keeps turning and won't come off
To insert a new cord, hold the round plastic container where the nylon cord comes out so it stops turning, then you can unscrew the bottom part of the plastic holder (retaining screw). The cover and inner reel will come off so you can wind new nylon cord onto the reel. Insert the ends of the nylon cords into the outlet holes and replace the cover and retaining screw.
Oct 04, 2012 | Garden
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
Should the plastic covering on front of kor-63mdc micro door be removed ,leaving a mesh front
NO! It provides vital protection for the metal mesh.
If it is damaged or gone, grease, food particles and moisture will accumulate on and damage the mesh, then microwave leakage is possible, which can result in a fire.
If the plastic is damaged or gone, it must be replaced. You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 18, 2010 | Daewoo Microwave Ovens
Front Strut Top Cover not flush protruding from
That is fine as long as it is not loose and making noise when you are driving. In some cases this is a sign that your strut bearing rubber bushing assembly are wearing out and need replacement.
Apr 03, 2010 | 2001 Volkswagen Golf
I need the radio wiring color codes to a 2008 dodge avenger sxt
Clarification Request Posted by emissionwiz on Mar 17, 2010 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Red Car Radio Accessory Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Green/Orange Car Stereo Dimmer Wire: Green/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: White/Black Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): White/Blue Left Front Speaker Negative Wire (-): Black/Blue Right Front Speaker Positive Wire (+): White/Red Right Front Speaker Negative Wire (-): Black/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Yellow/Blue Left Rear Speaker Negative Wire (-): Gray/Blue Right Rear Speaker Positive Wire (+): Yellow/Red
For some unknown reason your answer was changed to a clarification
Mar 17, 2010 | Car Audio & Video
I am looking for a replacement part for my Toshiba TV (model # 57H94), the bottom speaker cover.
What is the problem with the speaker cover? Is just the mesh damaged? If so you would have better luck replacing the mesh fabric yourself. You can purchase good replacement mesh fabric and adhesive at www.parts-express.com under speaker building supplies.
Oct 13, 2009 | Toshiba PSS421S TV Speakers
No volume for rings/texts
take the back cover off and see if the black mesh material is intact and still covering the internal speaker. blow out the speaker area if you can, and take your battery out of the phone and leave it out for about 20 minutes. put it back in and verify that your volume is all the way up, and its on the LOUD setting. also, try using a different ringtone, or just a differend sound all together......if you can, use a flashlight to shine through the mesh material that covers the internal speaker ( on the back of the phone, behind the back cover, to the left of the flash and lens) and try to see if it atleast APPEARS intact.......another thing you can try, would be to call that phone, and while the phone is ringing, place it up against your ear, without the back cover on the phone, and see if you can hear anything at all.
if this does not work, then you either have a bad speaker, or a bad conenction. either way, you need to take the phone back to the store and have them take it apart and inspect it, or just have them send it back to the manufacturer for repairs.......and enjoy the piece of **** phone that they give you to use in the mean time....sorry about the joke, but thats the way they usually do it......especially t-mobile....
Sep 20, 2009 | RIM BlackBerry Pearl 8100
Altec Lansing IMT702
http://www.youtube.com/watch?v=ztxvAAKhwU8
May 06, 2009 | Altec Lansing Inmotion-IM600...
Bass Flow Tube
Carefully pry off the gray metal mesh covering the speaker. Don't pry on the plastic ring - you have to remove the metal mesh from the plastic. Remove the six screws holding the speaker in place, and remove the speaker. Finally, re-glue the tube into the port. Wait for the glue to cure before turning the speakers on again.
Feb 14, 2009 | Logitech X-230 Computer Speakers
60 people viewed this question
 Grubhead
Grubhead
