Question about Battery Technology Computers & Internet
I Have a Toshiba satelite laptop. It has a week battery. It can't be swithed on when the battery has been removed so that it should be using AC power. But when I put in the battery and plug the pc to the AC power, it switches on but only for few minutes then I get the messege that the the battery is running out of power. How can I solve that problem?
    Problem Solver:
  • 19 Answers
You have a bad plug on the end of the power supply a loose jack on the computer or a bad power supply you need to test the power supply with a volt meter to see if it is putting out any power if it is you have a bad connector on the pc or an intermittent connection on the power plug end. get a new battery before you blow something up. it is not good for the power supply to run the compputer all the time. it will shorten the life.
Posted on Jul 18, 2009
Testimonial: "You gave a helpful solution. you were right saying that it had a power adapter that is outputting insufficient amount of power. Thanks for your help"
I just bought a new laptop battery for my toshiba satelite A105, but the problem is the changing the battery, when the battery is low then i plug in the AC adapter the laptop keeps using the battery...
Make sure that the replacement battery is registering as a proper replacement and not a knock-off. This will sometimes cause them to act funny.
Check the power settings under Control Panel. It's a long shot, but there might be a weird setting in there.
Nov 10, 2012 | Toshiba Satelite A105-S4102 Notebook
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Hi I have toshiba A200 satelite laptop, for the past two weeks my system gets restarted often, like when i unplug charger pin, when i boot my system. Is it mobtherboard problem.
More likely a battery problem. When you plug in or unplug the AC, there has to be a current surge from the battery to fill a couple of capacitors. If the battery is low, that will cause a failure and restart. How old is the battery. They never last more than 3 years.
Dec 13, 2010 | Computers & Internet
Toshiba satelite A135-s4527 only powering up for a few seconds
remove battry and clean it from dust.also clean dust from laptop.
check that your battery is working proper.
Jan 03, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
53 people viewed this question
Top Battery Technology Computers & Internet Experts
Computer Links
Terry Schallert
Are you a Battery Technology Computer and Internet Expert? Answer questions, earn points and help others
