Question about Goodman GMS90703BXA Heater
When you change the filter
Is there a rest switch it wont blow out air.
  • Chardi Nov 24, 2007
    Can hear the furnace come on but the blower is not coming on.
There was a hose clogged thats why it wasn't working
Posted on Nov 20, 2007
  • 625 Answers
There is a door switch interlock. when the door is closed the switch makes up and the unit should run.
Posted on Nov 19, 2007
I have a 1987 Suzuki Quadrunner 4x4 It wont start unless I blow air in the air fitter box, then it runs fine. Any one know what this could be??
Have you changed the filter recently? Maybe air flow is blocked and needs cleared or cleaned
Jun 27, 2014 | ATVs
BP Blower wont idle with filter on
Because it's a troy bilt... Obviously the carb has become plugged
Dec 22, 2013 | Troy-Bilt 32cc 4Cycle Backpack Blower
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
Car change a/c filter light is on as is engine light and it blows hot air
The A/C Filter light is a gadget. Not tied to any vehicle system. Rest to zero, with buttons top of dash ,by the two vents
Mil Lamp (engine lamp,check lamp) is a possible system malfunction. Retrieve code and diagnose
Jul 28, 2010 | 2004 Lincoln LS
My A/C is not blowing hard
That high pressure rest button is most likely it(A breaker from the wind/mess), try resetting it.
Aug 11, 2009 | Ruud UAKA037 Air Conditioner
Water in gas tank and fuel lines on a Chevy 1998 S-10......wont throttle up at all, will run at idle.....when throttle up it chikes itself out like it flooded...but will idle as low as 400rpm..have changed...
THERE IS NO SUCH THING AS A RESET SWITCH ON THE FUEL PUMP. IF YOU HAVE WATER IN THE FUEL SYSTEM THE ONLY THING YOU CAN DO IS REMOVE IT, PHYSICALLY. DROP THE TANK, CHANGE THE FUEL FILTER, REMOVE THE THROTTLE BODY, AND GET RID OF THE WATER. AND DON'T FORGET TO BLOW IT OUT OF THE FUEL LINES.
WATER MOLECULES ARE BIGGER THAN FUEL MOLECULES AND WILL NOT GO THROUGH THE FUEL INJECTOR NOZZLES. YOU MAY EVEN HAVE TO REPLACE THE FUEL INJECTORS IF THE WATER DID DAMAGE THEM.
Jul 10, 2009 | 1998 Chevrolet S-10 Pickup
Starts but wont stay running
Check your gas filter. When you ran out of gas, you got any rust in your lines and filters. Change the inline filter and use an air compressor and blow the line TOWARDS THE TANK. Take the gas cap off first. There is also a filter in your tank.By blowing the line you may unstop that filter.
Apr 03, 2009 | 1988 Ford Aerostar
My car wont blow out heat or air
sounds like your fan is burnt up
Dec 09, 2008 | 1995 Mercury Tracer
Wont change mode
changing mode all the time, beeping all the time, sounds like my wife - slap it!!
Jul 10, 2008 | Maytag Chassis Built-In Air Conditioner...
Goodman GMS90703BXA Heater Logo
54 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
