Question about Microsoft Windows XP Professional
Device manager is showing PCI Deice missing
I fomated my pc and when loaded xp professional again the device manager is showing pci device in yellow colour. I tried so many sound drivers but none could be installed. Mother board is 915 g
  • 29 Answers
Hi you should try the motherboard website for drivers. Usually drivers that come with Windows XP are generic.
Try going in to Device manager, Uninstall the driver and reinstalling the driver that you downloaded from motherboard vendor site.
Posted on Jul 18, 2009
PCI Slot 5 (PCI bus 1, device 7, function 0) IN DEVICE MANAGER THERE IS A YELLOW QUESTION MARK NEXT TO PCI MODEM.EVERYTHING SEEM TO BE WORKING NORMALLY BUT WHEN I START MY COMPUTER I AM BEING INFORMED...
If you don't need the modem, you can safely disable this questionmarked device in Device Manager, so it does not nag you every time you start Windows.
As far as the disk is concerned, you may try going to Disk Management (in XP you right click My Computer and choose Manage, a Computer Management window will show Disk Manager will be on the list near the end).
Study the list of volumes listed in Disk Manager; if you see a volume of more-or-less the same capacity as your ext. disk, and without a drive letter assigned, than right-click that volume and choose Assign / Change Drive Letter. Choose a letter farther into the alphabet so it doesn't interfere with any existing volumes - my favorite is X: for eXternal :) - and confirm.
After that operation the drive should appear in My Computer.
Jul 24, 2011 | Computers & Internet
My pc shows yellow color in device manager pci
first of all right click on the yellow shield you will get a pop out menu choose update driver if that not help then you have to reinstall your hardware
May 14, 2010 | Gigabyte GA-7VA Motherboard
What is PCI bus, device 16 function 1 Code 28
While I do not know exactly what would cause your computer to display that code, I can safely assume that you are using a pci sound card if you are getting a pci error, and your sound is not working. In short, yes, the pci problem is almost definitely related to your sound problem.
Sep 14, 2009 | Microsoft Windows XP Professional
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
PCI Device not installed
Try installing Windows update and drivers for sound device. Which motherboard are you using?
Mar 31, 2009 | Microsoft Windows XP Professional SP3 Full...
Pci device
Yepp, you can do that! Its not XP who desides if you can or not, its your motherboard, if u have a free pci-slot you can install it.
Put in the pci device in the free slot, start your pc, xp will find it and ask if you want to install it. Now you have two choises
One: you let xp do all the installation
Two: you selec to install it your self via a cd where you have the drivers, you can also install it from drivers stored on your HDD,
After the installation dont forget to check device manager to see if there are yellow exclamation marks (!) next to the device.
Good luck to you
Take a minute to vote
Nic
Jan 30, 2009 | Computers & Internet
Sound problem
Hi thr,
If u r runnin Windows XP, Go to control panel. click on system->hardware->Device Manager n check to see if the sound drivers r installed properly. If the lists shows a yellow exclamation mark on PCI DEVICE, It means u need to install microsoft universal audio articeture drivers first. u can search for it on yahoo or any other searchengine to get the link. download and install microsoft uaa drivers, Uninstall the PCI device from device manager and re-install the audio drivers. I hope it works this way. Thank u
Nov 06, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 710m PC Notebook Problem
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
It sounds like all your software drivers got blown away or can’t load. If that’s the case, try running diagnostics. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 31, 2008 | Dell Inspiron 710m Notebook
Pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
Microsoft Windows XP Professional Logo
139 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
