Question about HP Pavilion Media Center TV m7360n (EL409AA) PC Desktop
Carlos Hello, i need help, and i hope you can help me, i have a DELL with the FOXCON LS 36, DUAL XEON, byt it has only 16 mb of video, then buy a new video card wiyh 256 mb but when i installed the car its not functiion and the computer dont show anything, but if i desinstallation the card and use only the original video it works good, some bady can help me?
  • 328 Answers
I assume you have switched the monitor cable in the back to your video card before booting up. Also you must disable the onboard video and driver too by Start----->Control Panel----->System----->Hardware----->Device Manager and make sure the driver for the onboard video is disabled. You have to also change the BIOS settings by rebooting and pressing F4, F1, F2 or F6 (varies on computers) Once in BIOS, you have to use the arrow keys, Esc and Enter to navigate. Goto the Video Display options and change the onboard video to your new card 256 MB. Collow on screen promts to save it and reboot again. Should work now.
Posted on Nov 19, 2007
Dell 690 powers off randomly yet frequently
This problem is common when hardware parts temperature raises over a certain point, and happens for safety reasons.
The temperature problems always come from insufficient cooling, stuck coolers, dust or missing thermal paste on hardware pieces.
You can try opening the case and cleaning the pc using a vaccum cleaner.
Hope it helps.
Jul 23, 2014 | Dell Precision Workstation 690 - 750W...
Remove front panel from dell precision 690
Hello
Usually, side casing must be removed before pulling the front panel out.
If you don't notice any screws, there are only clips, but take care when prying it off as there are some wires that lead to the front panet at the power button, leds, etc.
Hope it helps
Dec 06, 2013 | Dell Precision Workstation 690 - 750W...
NO DISPLAY PROJECTED. VERIFIED MONITOR. DELL SHOWS LIGHTS 1 2 3 IN GREEN.
I don't think that machine has an onboard video card, so try removing the existing video card from it's slot. Clean the contacts on the video card GENTLY with a pink pencil eraser. The eraser has just enough abrasive in it to clean the oxidation off the contacts. Replace the video card and see if it works. If not, test with another video card.
Hope this helps!
Joe
Jun 04, 2011 | Dell Precision Workstation 690 - 750W...
Display drivers
Hi sawdapezu,
You can download the display/video driver of your Dell Precision 530 here:
Hope it helps,
Thank you for using FixYa.
Feb 03, 2011 | Dell Precision 530 XEON Workstation Dual...
Im looking for drivers that can upgrade it from 16mb to 64 mb
Unfortunately you can not upgrade your "NVIDIA Vanta LT 16 MB AGP" Graphic card from 16 MB to 64 MB by installing or upgrading the driver.
It comes in 4-16 MB configurations and the max video memory is 16 MB for that type of graphic card.
You have to buy new graphic card which is capable 64 MB memory.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 10, 2010 | Compaq NVIDIA Vanta LT AGP Graphic Card
Videoadapter in Dell 1650 server possible ?
8MB sounds like it is only recognizing onboard video.
Check the BIOS setup screen for video options. You may be able to select or enable PCI video.
If that does not work, Dell has lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis and call Dell.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Jan 13, 2009 | Dell PowerEdge 1650 Server
Vidoe Card
Yes. Have you installed the software and driver for the new video card? If you had "onboard" video before you may have to turn it off in the BIOS setup screen.  Additionally if you had a different video card you may have to remove the software for it but not usually. Need more help , just ask.
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central
Jan 08, 2009 | Dell Dimension 4700 PC Desktop
Video card for Dell 531s
This computer uses a PCIe-16 slot, so any half-height dual-monitor card with DVI would do for you. The XFX Geforce 7200GS with 256MB memory has dvi and vgb outputs. It supports the resolution of your 20" Syncmaster, and is around $40 at Newegg.com at this time.
Nov 04, 2007 | Computers & Internet
Problem with cs2
Hi, According to Adobe, the minimum requirement for Adobe Photoshop CS2 are: Intel Xeon, Xeon Dual, Intel Centrino, or Pentium III or 4 processor Microsoft Windows 2000 with Service Pack 4, or Windows XP with Service Pack 1 or 2 320MB of RAM (384MB recommended) 650MB of available hard-disk space 1,024x768 monitor resolution with 16-bit video card CD-ROM drive Internet or phone connection required for product activation With the 384MB recommended memory and Windows will use say 120mb, it might be better to have 512 of memory. Of course the lower your processor speed, the slower the software. With the minimum of 650MB of available hard-disk space, you would still need a pretty big swap file say 1024mb if with 512 memory. It is also to your advantage if you constantly defrag your HD. Adobe does not specify a video card requirement but you would probably be better off with a 128 or a 256 mb. Hope this be of some help/idea. Post back with details of your motherboard/PC or should you need additional information. Good luck and kind regards.
Oct 01, 2007 | Adobe Photoshop CS2 for PC
HP Pavilion Media Center TV m7360n (EL409AA) PC Desktop Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
