The printer stop to print when it was printed 2000 lines.
SOURCE: HP Deskjet 1100c Printer. Stops printing
hmmm..that's a little weird..did you have any power glitches recently? you may need a new fresh set of drivers for that printer..
get em here
SOURCE: Error: Printing data is inaccurate, printing processing is stopped
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
SOURCE: GenicomTally T6215 line printer not printing on edges
If your still having problems? 1st make sure the gap is not to tight(cause the to ribbon to drag up with paper). 2nd While printing in test mode, carefully lift up or push down on the ribbon where it comes out or where it goes back in the catridge. After doing the 2nd you should see the exact same thing as will stop printing on right and left edges. Remove the ribbon, their are 2 philip screw on the left and right side of the ribbon deck, loosen them(they will not come all the way out, held on by clips) lift the rbbon deck up and reseat it... tighten the screws back down. last you may have some bad ribbons...
SOURCE: printer prints with lines along pictures
just clean the head of ur cartirage if still same problem contact ur sealer u bought it from or check the computer repair persons near to your place...
