Service centere of intel in chandigarh
I have a problem with my speaker output jack the rear one with motherboard is not working i am running the speakers on the front jack means the motherboard and sound drivers are working fine and i can run the speakers on the front the rear jack is the problem.
  • 62 Answers
Hi and welcome to Fixya!
yes because the audio port needs to be replaced from the motherboard ..
Thanks for using FixYa!
Posted on Jul 18, 2009
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
I have a graphics board with an HDMI output. In order to include audio on the HDMI output, I need to connect a jumper cable (provided with the graphics board) from the audio on the motherboard to the...
The HP m7260n has an SPDIF connection on the motherboard. It's near the spot where the VGA port is connected to the board. I suspect that is what you need. The layout diagram for the P5LP-LE is available here: https://support.hp.com/us-en/document/c00864946 .
The specifications, including the motherboard information, for the m7260n are available here: https://support.hp.com/us-en/document/c00507225 .
I hope this helps.
Dec 18, 2017 | HP Media Center m7260n (EG642AA) PC...
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Jun 03, 2009 | Intel D865GBF Motherboard
Primary speaker output jacks don't work
here in your manual http://www.fixya.com/support/p235198-kenwood_vr_409_receiver/manual-19163/page-14 on step 8 you need to make sure this is set to normal or large speakers for the surround speakers
here shows how the surround speakers are to be connected http://www.fixya.com/support/p235198-kenwood_vr_409_receiver/manual-19163/page-12
and dolby digital will not work unless the device connected has the coax or optical digital audio connection connected
Jan 03, 2009 | Kenwood VR-409 Receiver
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Nov 10, 2008 | JVC SPPWA670 Subwoofer
Creative 5 in 1 speaker set up
buy jack to connect all the cables.
because computer are only two output audio terminal.
Oct 14, 2007 | Creative Labs FPS2000 Computer Speakers
No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Sep 15, 2007 | Acer Aspire L100 PC Desktop
Audio Jack Problem
check any other driver installed before the current driver......
Aug 15, 2007 | Intel D946GZIS Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
