Hi Vicky.Your rear view mirror,as it is off is thear a small metal stub on the windshield? If so it means that the clip must be changed.If not then you will have to purchis rear view mirror glue and stick it back on. PS : WHAT IS BEHIND YOU IS NOT INFRONT.
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Most probably you are seeing a lot of clutter in the bonnet to put your hand in and change it right? The best way sometimes is to unbolt the headlamp , move it out change the bulb and back in. But another way would typically be to remove the battery (and battery holder plastic box) or air box (whichever is in the way) and then you should be able to access the headlamp cover from behind. Anyways in both cases you should find a metal clip holding the bulb. Unclip the bulb whilst making sure that you dont touch the new bulb with you hands while putting it in. Press its metal clip in place again. and be sure to mount the plastic cover at the back properly so no water goes in the headlamp if its raining.
If the sprayer fell off the hose and you see no threads to screw it back on with, then the retainer clip has gone bad. Unscrew the sprayer at the bottom of the piece that came off the hose. There should be a little metal clip. That clip holds the sprayer on the hose. If the clip came off once it will again. Buy a new sprayer assembly with a new clip, unless someone has one sitting around.
There is a small groove in the end of the stud on the vacuum that the wheel fell off of.
Slide the wheel back on the stud, put the washer on then put the ends of the half clip in the grove on the stud pushing on the back of the clip with a small screwdriver on the clip to lock it back in the groove. The old parts may be still in the wheel if it rattles. There should be a plastic cap on the wheel like a little hubcap, pry it off with a screwdriver carefully so you can put it back on after the clip.
Please rate this solution if it helps you.. Thank You....
hi
the metal clips are those wich holds the key in place
u need them to be pushed agianst the movment of the key soo they will keep the key in "their hands"
grab a big set of tweezers and push the clips separate
then push the key to its place (in the right direction)
check very closely so the key inserts its place
a couple of tries and you will success to do it
good luck
