Question about Kitchen Ranges
Everhot deluxe 204 wood stove oven temperature
Hi I am having trouble getting the oven temperature of my everhot deluxe 204 above 100 degrees. I usually gets up to 250 no problem but I think we have messed with the lever controls and we have no instruction manual. Please help!
GodBlessU
  • 3513 Answers
SOURCE: oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Posted on Sep 09, 2009
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
  • 131 Answers
SOURCE: Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Posted on Mar 10, 2008
  • 1073 Answers
SOURCE: I hate my Westinghouse Fan
in the owners manual with most of the ovens it will tell you haow that you can vary the temprature of the thermastat 50 degrees up or down but not 100 you can try that and if it does not fix the issue then you will have to replace the oven sensor
Posted on Apr 27, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
What needs fixed in my built in Tappen oven, model 12-1263-30, when it is 90 degrees off?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
The normal operation of a oven is the oven will rise 20-40 degrees above the set temperature and turn off. Then, when the oven temperature drops 20-40 degrees below the set temperature it will turn back on and cycle again. This is true except for the new accurate ovens.
Since you are getting heat your oven heating element is good.
You have a older oven.
Your problem is either the oven thermostat which cost over $200.00.
  • MFG Number 5303202782
25691587-pfxp0re3pkk4llvjptchxxrl-3-0.jpg Or, your oven control, which base on your oven age is no longer available.
Now, here are your choices:
1.) Take a chance and purchase the oven thermostat and install it. If this does not solve the problem you can return it less shipping and restocking charges.
2.) My professional recommendation is to put the old girl to rest.
You can:
a.) Go to a Sears Outlet (Scratch and Dent) Store, save a couple of hundred dollars on a new oven and still get a one year warrantee .
b.) Go to a used appliance store.
c.) Go to Habitat Stores - used appliance stores.
d.) Go to Second Chances Stores - Appliances removed from homes that were torn down.
Best of luck,
Peter
May 11, 2015 | Kitchen Ranges
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
GE-XL44 - OVEN DOES NOT HEAT ABOVE 100 DEGREES
Check the temperature probe. It should read 1100 Ohms at room temp.
Post back the results.
Dec 08, 2012 | Kitchen Ranges
We bought a house with an old wood combustion oven everhot deluxe 204. Unfortunately all the controls details have been erased with time. So we do not know where the highs and lows stands for the knobs. We...
Hi Jacqui and Sven,
Check these guys out...you'll have to call or write, but they should be able to answer any (and all) questions about the Everhot Deluxe 204. They even carry spare parts! Hope this helped.
http://www.woodstoves.com.au/html/everhot_parts.html#Everhot
May 06, 2011 | Ovens
The oven cannot keep a consistent temperature. It is mostly about 100 degrees above the selected temperature. My landlord replaced the stove about a month ago and the problem is worse now than it was...
It sounds to me like the oven thermostat is faulty, as this is what controls the temperature.
If you can , get a thermometer and place it in the oven and check the temp against the seting with the thermometer, if as you say it is 100 degrees above setting , then you need to replace the thermostat.
Feb 06, 2011 | Hotpoint Ovens
I have a magic chef black electric stove and i never used the self cleaning but i cant stop the process the door is locked and the stove is getting very hot
Hello there:
Magic chef ovens and various other models of ovens have this no cancel feature this is due to the intense heatthat is generated during the cleaning process Normally if you press and hold the cancel button for 10 seconds this may cancel it out but the oven door will remain locked untill he temperature gets back to around 100 degrees see the cleaning temperature are almost around 600 degrees ok also you can unplug the oven and leave it set for at least 1 hour to allow the internal reset feature to reset the oven ok this has been known to take care of this problem too ok
Hope his is very helpful for you
Best regards mike
Oct 13, 2010 | Magic Chef CER3725AA Electric Kitchen...
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
Oven temp will not go above 300 degrees
You need to check the thermostat in the oven. Go to your manufacturer's web site and download the technical manual for your stove. There should be a troubleshooting section in the manual. If not, and you are somewhat handy...
1. Disconnect the power from the stove.
2. Locate the thermostat and jumper it out.
3. Reconnect power to the stove and turn on the oven.
4. Wait a few minutes and see if the temperature goes above 300 degrees. If it does, replace the thermostat. If it does not, order a service call.
Don't forget to shut off the power again and remove the jumper.
Oct 05, 2009 | Kitchen Ranges
Oven does not heat over 100 degrees
Hi
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
777 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
