Question about Jenn-Air JJW8230D Electric Double Oven
F4 - what is it?
The top oven won't start. Just beeps with F4 on the panel. Any ideas?
  • elena23805 Mar 02, 2008
    my kenmore double ovens have f 3 and it keeps beeping and will not start
  • 473 Answers
F4 means it has a shorted oven temp. sensor and will need to be replaced.
Posted on Nov 19, 2007
When baking in top oven for any period of time my oven will start beeping with an F4 blinking on the oven temp screen? What is it trying to tell me?
Hello & Welcome to FixYa
F4 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. However, I believe it is the sensor as the problem is only with bottom oven. Please get back to me if you have any other questions.
May 03, 2011 | Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
My GE gas oven flashes a f4 error code several minutes after turning it on with a beeping.
Your temperature sensor located in the top right of the oven has shorted out and must be replaced.
The GE brand part is a little on the expensive side.
You can use the Whirlpool sensor at 1/3 the cost.
Sep 20, 2010 | GE Ovens
My oven comes on and reaches the right temperature but then it starts beeping and shows F-2 or an F-4 in the display window. Then it stopps cooking.
Your temperature sensor is inside the oven in the top rear section. It is metal about 3 inches long. You can remove it from inside the oven. The F2 and F4 codes is a bad temp sensor.
Nov 24, 2009 | Maytag CWG3100A Gas Single Oven
I am getting a F4 code and beeping. The beeping
Replace the oven temperature sensor. It is located in the back wall of the oven. 4-6 inches long,up high on the right or left side depending on model. Most can be changed from inside the oven rather than through the back.
Sep 02, 2009 | Kenmore Ovens
Oven comes on then beeps and a code F4 comes on
how do I solve a F4 problem in the Decor electric stove?
Feb 02, 2009 | Ovens
Errorcode F4 Amana ART6610E
Hello Welcome
F4 means on an Amana Range or Oven:
Condition is a open or shorted oven temperature sensor
Check and or Replace oven temperature sensor
Please remember to leave a solved rating before you leave
Huum at your service
Dec 21, 2008 | Ovens
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
Jenn-Air JJW8230D Electric Double Oven Logo
208 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
