Question about Craftsman 25cc Gas Line Trimmer
Where would I fine the spool retaining bolt? for sears weed wacker 25cc
  • 420 Answers
SOURCE: I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
Posted on May 14, 2009
  • 4 Answers
SOURCE: Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Posted on Jun 09, 2009
ar15guy
  • 3 Answers
SOURCE: Hve a Craftsman Weed Wacker 24 cc Need to find out
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
Posted on Jul 26, 2009
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a 2002-2003 craftsman
Hi
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 01, 2011
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
Need to fine gas tank replacement part for craftsman weed wacker model number 04182N501231
Hi mperez40
Go to the following webpage and you will be able to locate what you need and be able to order it also.
It is the Sears Parts webpage with will also have phone and email support in case you canhnot locate the part by yourself.
Please rate me
http://www.searspartsdirect.com/partsdirect/product-types/Grass-trimmer-weed-wacker-Parts
Jun 25, 2011 | Craftsman 25cc Gas Line Trimmer
I have a sovreign 25cc trimmer and was wondering where the idle screw is on it any ideas
Go to the Sears URL page listed and click on the sears number you find on your string trimmer and see the exploded parts of that model.
http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts
Apr 02, 2011 | Craftsman 25cc Gas Line Trimmer
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas weedeater. Engine runs, but the head won't run
Cut 1/8" off outer (aluminum) shaft. Lube inner shaft with STP or heavy gear lube this will re-engage worn square drive .Replacing inner cable is un-necessary this is normal wear. Sears Master Tech BB
May 26, 2009 | Craftsman 25cc Gas Line Trimmer
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Craftsman 25cc Gas Line Trimmer Logo
85 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
