Question about Sharp Office Equipment & Supplies
How I know my lamp was broken? SF 7350 - Sharp Office Equipment & Supplies
    President:
  • Sharp Master
  • 990 Answers
Hello sir; I don't know which lamp, you are talking about , therehve two lamp in the machine;one is exposure lamp anoterone is fuser lamp; now to check the exposure lamp, lift the cover press print the scaner lamp should on otherwise this lamp is defected, now to check fuser lamp, you have to removed fuser unit, use ohm meter to check its continuity.
Posted on Jul 18, 2009
Se ve borroso que debo cambiar la lampara o que
Original lamp USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jul 13, 2012 | Epson Replacement Lamp Projector Lamp For...
Low heat error for samsung sf-565pr fax machine pl help
check the fuser heat lamp during initalize ,if heat lamp not glow then check the fuser thermostate
if open then replace the thermostate.
Mar 25, 2011 | Samsung SF-565PR/XST Printer
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
How do I zoom and focus the LV 7350? It is ceiling mounted. I want to make the image smaller so that people in the audience can see the image over the heads of those in front.
There are zzom and focus buttons on the remote if you have it. If not, use a safe ladder and use the zoom/focus buttons on the projector itself.
Good Luck
Aug 13, 2010 | Canon LV-LP11 Projector Lamp for LV-7345,...
I have a Canon LV-7350 that comes on for 15 secs then turns off.. everything is hooked up correctly. and I have swiched out the bulb to rule that out.. anyone ever seen this?
Hello :
It must be overheating problem . Check the fans . If the fans run properly , then you need to check the fuse or the power PCB [printed circuit board ] . If everything is okay with all of those , then I recommend you to replace the bulb .
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
please rate !.
Apr 12, 2010 | Canon LV 7350 Multimedia Projector
Open heat error ?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Nov 18, 2009 | Samsung SF-565P All-In-One Laser Printer
I have a Sharp SF-2030 copier and it is diplaying a F1 code.
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
Feb 21, 2009 | Sharp SF 2020 Copier
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
Lamp problem
Could be an overheat problem, check any fans and filters are not clogged with dust, lack of ventilation and cooling will trigger a safety shutdown
Feb 06, 2007 | Canon LV-LP11 Projector Lamp for LV-7345,...
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
