Question about Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100
What will a 2.5 hp engine run please? - Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100
    President:
  • 1,714 Answers
It's a 1100 watt gen, so you have 1100 watts available to use. All electriccal equipment is rated it volts and watts. Just do the math...
Posted on Aug 07, 2009
Hp mini
hi Cliff,
If it is a BIOS password.
Go to this site.
http://dogber1.blogspot.com/2009/05/table-of-reverse-engineered-bios.html
Look for Hewlett-Packard/Compaq Netbooks 10 characters click on Windows binary.
Download then run.
Put in your CNU# and there you go.
Please help others.
Just a note - if you participate in this thread I must inform you that these services are not endorsed by HP, and that HP is not responsible for any damage that may arise to your system by using these services. Please be aware that you do this at your own risk.
Nov 26, 2011 | HP Computers & Internet
I don't know what oil type to use for a Tecumseh 8.0 hp engine
Tecumseh recommended straight 30 weight (30w) for summer use. You can use 10w30 also.
5w30 for winter use.
Use a heavy duty oil because air cooled engines run hotter than you car engine. A brand like Briggs&Stratton, Craftsman, Kohler.
I have used full synthetic like Mobil One with great success also.
If you have any other questions, please ask!
Jan 10, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor. Runs
It doesnt sound normal.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Jul 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Just bought a honda f400 tiller would like to no what hp it is please
hi, i think you'll find its a g 35 engine, 3.5 h.p. 144cc. dates from late 70s early 80s.i'm not clever, i've got an engine in the shed! running last year blackrodd@hotmail.co.uk
Apr 23, 2010 | Honda Garden
20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a snapper riding mower with 11 hp b&g engine what is the setting for the low speed idle screw
would this screw be a stop screw on the throttle. because if it is the farther out you turn it the slower the engine will run.if this is not the case would you please email me personally and i will guide you through the steps for the othe screws...good luck
jonathanhuffman@charter.net
Mar 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsamen 18.5 hp battery keeps draining
Either the battery is not being recharged when the engine is running or there is a current drain when stopped. If you are not knowledgeable about electrical tests you can check for current drain by disconnecting the battery negative cable when not running. If the battery stays charged then you need to find the current drain. To check for no charge when running, turn on the headlights with the key on but engine stopped. Start the engine and see if they become somewhat brighter. If brighter, the charging system works. If not, there is a problem in the charging system which needs to be confirmed with a voltmeter.
Jun 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
13HP honda engine
Try running without filter if ok clean filter and put back. This is and air/fuel mix problem,did you adjust idle screw??
Please rate. Thanks
Mar 31, 2009 | Northstar Garden
Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100 Logo
150 people viewed this question
Top Makita Electrical Supplies Experts
obsteiner
Tom Chichester
Ogbonna promise
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
