Question about Kitchen Ranges
Display light out - how can i replace it
I have an Amana range oven display light that recently went out, but I can't figure out how to replace it.  I have removed the top of the oven and the back plate, but I still can't figure it the way, the stove and oven actually still work great, but we can't use the oven because we can't see the temperature display...any advise?
  • 248 Answers
Re: Display light out - how can i replace it
If the display is out you probably need to replace whole range control. Also known as the clock assembly. Be sure to take model and serial number, also manufacturing number if it has one, when you go to get new part.
Posted on Nov 19, 2007
0 characters
3 Points
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
Jun 28, 2013 - Uploaded by
... symptoms: Clock and display does not work At: For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Amana Eletric Range, not working
check to see unisulated wires......but dont forget to turn the breakers the way use electrical tape to insulate open wires.
Feb 05, 2014 | Amana AER5844VAB Electric Range
Amana aer5330bas0: in the midst of cooking, the oven had just been turned off and the stovetop was in use, first one burner would not come on, then the one that had been on went off, and then the entire...
This is how the "control clock" goes out. You will need to replace it and all will be good. Here is the part to order and on that same page is a video to show you how to swap them out.
The part also come with a 365 day, any part, any reason return policy.
Oct 19, 2013 | Amana ACS3350 Gas Kitchen Range
Element burned out on the bottom of the oven. replaced the element, now I get no heat on either element. It just clicks twice and stays at 100degrees on the display.
Jul 21, 2011 | Amana AER5515QA Electric Kitchen Range
Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
Feb 08, 2010 | Amana AGDS902SS Gas Kitchen Range
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
Our digital display says F1 and we cannot set the
This usually means a failure in the control board. We rebuild these at
Oct 10, 2009 | Amana ARGS7650SS Gas Kitchen Range
Digital display is flashing F 5 and won't turn off
maybe you need to replace the electronic range control
Jun 22, 2009 | Amana ARGS7650SS Gas Kitchen Range
Kitchen Ranges Logo
161 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
