Question about Handspring Visor Prism Handheld
I need the pass code for a Visor Go R57 Blue tooth
    Problem Solver:
  • 5 Answers
The pairing passcode is 0000
Posted on Aug 11, 2009
Whats the code
Posted on Aug 06, 2009
Mine is 0000
Posted on Jun 27, 2010
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
9xxPlantronics pass key to register bluetooth for PS3
to use the pass code for your blue tooth device you must first put the device into discovery mode then most blue tooth manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. i hope this helps
Feb 26, 2011 | Plantronics - Bluetooth Headset Plus Base...
Need a pass key for madcatz bluetooth headset
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 23, 2010 | Cell Phones
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
Visor bt, i need a passkey code. i have no idea what this is
Yes had same problem. all the usual 0000, 1234 etc access to the device was denied...on the point of binning it.....However found the answer... Get your phone to the point where its recognised another device ie the bt visor , select and its asking for password. ...now ...Turn on BT Visor BUT continue to hold main button for several seconds. There will then be another beep and light flashes alternately red and blue now insert 0000 into your phone and ok...this should then pair the devices.
Good luck
Jan 16, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Im tryin to pair my ST ONE r57 with my phone and its asking for a passcode and i have lost my user manual
Factory Setting is usually 0000. In order to pair with your mobile (Max 8 phones), Depress green button on ST ONE R57 for 5 seconds approx. Light will flash red & blue, indicating that device is in pairing mode. Phone should have "Bluetooth" switched on (in settings) and search mode activated. Good luck
Dec 10, 2009 | Handspring Visor Prism Handheld
I need a set of instructions for my visor go r57 can you help please
Go to http://www.supertooth.net/down_light.html. It is almost the same
Aug 03, 2009 | Handspring Visor Prism Handheld
Camera phone bluetooth
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Hope this can be of any assistance. Thanks!
Mar 19, 2009 | Cell Phones
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Handspring Visor Prism Handheld Logo
767 people viewed this question
Top Handspring Computers & Internet Experts
ray gallant
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
