Question about Bogen Communication Manfrotto 785 Modo Maxi Photo Video Grip Head Tripod
Whats the bit that attatches the camera to the stand called
Not getting any sound when I record
Is this tascam cc-222 mkiii really between digital camera"s? Although I do know a little bit of recording, I can't answer short questions like this. Not knowing what is attatched and where. and what settings you already tried.
Nov 01, 2013 | Cameras
I have a polaroid t730 camera and have been able to upload photos to my hp laptop in the past. however, upon trying to upload photos now, my computer does no seem to recognize that the camera is attatched...
now my computer does no seem to recognize that the camera is attatched at all,
  • Do you mean to say it recognized the camera at one time in the past?
  • What happens when you attach the USB cable?
  • What operating system are you running on your computer?
  • Did you try to re-install the drivers?
Jul 04, 2011 | Polaroid T730 Digital Camera
Where is my fuel regulator on my 91 cavalier
Along the reaer or the motor on the top is the fuel rail. It has the four injectors with their respective wiring harnesses. They all look identical. On the driver's side of the fuel rail is a metal cylinder standing vertically and suspended by the fuel rail mounting bracket. the fuel connection come out of the bottom and a vacuum lines is attatched on the top. I believe you need a T-27 torx bit to remove it.
Apr 06, 2010 | 1991 Chevrolet Cavalier
My wifes Kitchen Aid ksmc50 (rrk90) mixer leaks grease/oil from the rotating plate that the beater/dough hook attatches to.The grease/oil leakes from around the outer edge of the plate as well as from...
the rotating plate needs to be pulled of and clean the grease out and only put two teaspoon dabs on ether end. to pull it of you will need to push the pin in the middle out and just lightly tap it back in.
Feb 15, 2010 | KitchenAid K5SS Heavy Duty Commercial...
The hook where the camera strap attatches broke, is there a way to replace it?
Yes, Your camera cover is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 08, 2010 | Kodak EasyShare M853 Digital Camera
Can u take the bit off that attatches the stand because i want to hang mine on the wall?
Yes allmost all flat screens are wall mounteable. It will require find the screws or bolts holding the table mount to tv and removing. If your tv has extra threaded holes on back then it is mountable.
Dec 31, 2009 | Samsung LN-R268W 26 in. HD-Ready LCD...
Bought a kodak 763 camera at Sam's wholesale
whats the exact model of your camera?
when did you buy it? exact date of purchase?
Nov 26, 2008 | Kodak D-22 (1756824) Dock / Cradle
I have a nikon d40 and just purchased a 52mm lense reverse ring for it but when i attatch it to camera it keeps saying lense not attatched. what am i doing wrong?
You need to switch to Manual (M) mode. You won't be able to meter through the lens. Nor will you be able to autofocus.
Aug 29, 2008 | Nikon Cameras
Sony Cyber-shot DSC-W55 7.2 Mega Pixels
I think, Back Light of LCD in your camera is bad/ defective. You should contact nearest Sony repair facility for proper repair.
Jun 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Photography Logo
32 people viewed this question
Top Bogen Communication Photography Experts
Tony
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
