Question about Hotpoint Aquarius WMA42 Front Load Washer
When the wash is finished it doesnt drain the
When i put a wash on and it finshes it isnt draining the water from the clothes and they are left soaking? and also the lights on my machine flash half way through a cycle?.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
 Make sure that there is no blockage in the drain hose and that it is not kinked.  Is the drain hose installed correctly?  If you have connected your machine to a sink waste system, make sure that you have cut out the membrane from the under sink drainage system.
 Ensure that the drainage system, standpipe or under sink connection is free from any blockage. - If any of the above are found to be the cause of your problem you will need to run the machine through a spin only programme.  If you have chosen ‘Rinse Hold’, the light will flash until you press the ‘Rinse Hold’ button to continue the programme.
Posted on Jul 19, 2009
Fisher and paykel washing machine top loader doesnt spin dry the clothes well. There isnt any water in the machine after the spin cycle but the clothes are heavy wet. What's could cause this?
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
Nov 05, 2016 | Fisher and Paykel Washing Machines
Washer leaking water after the spin cycle is finshed
Check the actual drain to see if it is clogged. Check all the drain filters. Check the drain sensor to see if is turning off too early. If there is any doubt, change the drain sensor!
Jan 01, 2013 | Kenmore Washing Machines
My FP washing machine has starting leaving brown sludgy marks on my clothes. Do I need to descale the machine? Im in New Zealand and the water isnt particularly hard. Thanks for your time, Emma
I'm guessing you use fabric softer....Get some finish dishwashing powder and put a wash on with high water level with no cloths in it. let it do it's normal wash but before it drains any water out, pause the wash let it soak over night. next day unpause it and let it finish. Repeat if needed and do the same thing again with out any dishwashing powder in it to make sure it rinses all the soap out.
The black sludge is cause by using fabric softener. The costic in the finish powder will eat in to the sludge and soften it. If its really baked on it my need to soak for longer, more powder or it may need to be stripper and cleaned.
Mar 22, 2011 | Fisher and Paykel Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
204 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
