You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dear Fixya,
Thank you for your response. I have meanwhile located a source of drive belts (Maplin Electronics) and feel partly confident that I will be able to suss out how the belt should be fitted.
Regards, AEFlower.
Here's what to do: After you've chosen the photo you'd like to print, make sure you press Layout on the printer control panel to select a layout for that photo. Press the button repeatedly to move through the six layout options. When a memory card is inserted, the selected layout is displayed in the bottom center of the printer screen. All photos selected from the printer control panel will print in the selected layout.
For more information, here's an easily clickable link to the manual for this printer. This link is part of the HP official web site. http://h10032.www1.hp.com/ctg/Manual/c00378138.pdf
I hope this helps you!
- CBR2009
Without investigation it is impossible to know what failed. There are a number of boards in that set where there is fairly high current used. It is possible that some components have failed.
The Panasonic service rep would service the set by swapping out the failed modules. If the set is an older model the modules may no longer be available. You can take the set in for an estimate to see if the parts are available, and to see if the set is worth to service.
