Question about D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point
DWL-2700AP reset default settings
How to reset default settings in dwl 2700 ap.
  • 44 Answers
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
Posted on Jul 19, 2009
After reset the button of d-link. It takes user id- admin and password is nothing. type only user id - admin. without password it will open at ip 192.168.1.50
Posted on Mar 14, 2011
I lost the admin password for my DWL 3200P AP but i dont want to reset it because of the configuration that is on the AP...is there any way out by not loosing the configuration.
First try with the default setting for your router.
Default IP Address :- 192.168.0.50
Default admin username :- admin
Default admin password : Don't enter anything keep it blank.
If this will not work then you have to reset your router.
Thanks for using FixYa.
May 16, 2011 | Computers & Internet
Dwl-2100ap will not update firmware
1) Reset do default the device (rear reset button)
2) Set your PC a IP like 192.168.0.xxx (defaul IP address for DWL-2100 AP is 192.168.0.50)
3) Connecto via browser to 192.168.0.50, defaul login
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and selectInternet Protocol (TCP/IP), click properties, click set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
If this information can help you, please rate me ;)
Aug 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Here are the steps to reset the access point from D-Link's website:
Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
http://support.dlink.com/products/view.asp?productid=DWL-2100AP
Mar 15, 2009 | D-Link Computers & Internet
DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
Feb 13, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
Cannot Access My DWL-3200AP
If you can browse internet via same device
Start/ Run/ CMD/ type "ipconfig" (w/o ")
Use default gateway IP address as your AP ip address..
Enable java and use IE (some devices prefere IE)
e remember to score this tip.
Jan 15, 2009 | D-Link AirPremier DWL-3200AP 802.11g/b...
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point Logo
3,668 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
