Question about Craftsman 10" Table Saw
Motor has started t0 smoke and trips circuit breaker
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sears Craftsman Motor
Capacitor Start
Motor Model 11312070 Cat No. 1207
Cy – 60 HP – 1 Volts -120/220 Amps – 14/7
PH – 1 RPM – 3450
Manufacturer No. – L6397
MFG Model – KS55CP-204
Came with Sears Craftsman 10" table saw model # 11329992 10. (1955 motor)
I'm thinking I need to look for replacement motor. How can I identify frame number?
Spoke to Sears Parts Department, they no longer carry motors
  • Anonymous Mar 30, 2014
    trying to replace a part on my craftsman model 103.22160 table saw. Sears tech say it is not longer manufactured so need to locate one on a shelf someplace. it is the flat teethed plate the tilts the blade.
  • 2,176 Answers
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a Sears 33gal vertical compressor. About 8 years old. I keep tripping circuit breakers whenever the compressor is activated and starts to pump. Please advise
either the motor is bad or the pressure relief valve is inoperative forcing the compressor motor to try to start with pressure already in the pump
Oct 15, 2010 | Craftsman Air Tools & Compressors
When I push start switch , the motor hums but will not start. The breaker then trips. Motor model number is 131 12171. Motor is manufactured by Mallory and is 1 hp. Manufacture model number is K...
The capacitor may have gone bad...give it a spin then turn on the swtich... if it goes the cap is the problem....if not then the motor is toast....
heatman101
Aug 17, 2010 | Craftsman 10" Table Saw
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Craftsman 30 gal compresser trips circuit breaker
That number does not come up on Sears parts direct, how ever a start capacitor you can have tested at any motor repair shop and likely get one to replace it from them as well,,,and can almost guarantee it will be cheaper than from sears anyway.
Feb 25, 2010 | Craftsman Air Tools & Compressors
Compressor won't restart with any pressure in tank
try replacing the capacitor. a bad start capacitor will not let it start under a load.
Jul 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Craftsman compressor motor/capacitor problem?
I had the same tripped breaker problem with a similar Sears model 919.195060 (25 gal) and luckily I had access to another, almost identical sears compressor to swap parts to diagnosis it. It turned out to be the run capacitor, but from what I was finding in my on-line research, it could have been a bad winding on the motor or the start capacitor just as easily. If your resistor is outside of the capacitor, just cut the wire right at the capacitor and add flag termnals Mine had 3 wires coming out of the capacitor (not the normal terminal cap style), and two of them were basically just tied together (same color). I didn't have an external resistor. I bought a GE 97F9614 run capacitor (40 mf, 370vac) and other than having to cut out a bit of the plastic on the mounting bracket and buying "flag" style 1/4" terinals from radioshack, it fit and worked perfectly. It seems if GE is the only one that has the right dimensions (1.75dia x 3.88 long, not including the terminals. That capacitor cost $27.50 with tax at a local electric motor shop. Sears doesn't even have any info on the motor parts, like capacitor - they want to sell you a new motor for almost as much as a new whole compressor. I ended up looking at parts forr the motor on a Devilbliss (that's what the 919 means on the model number, that it's made by Devilbliss), but it was not an easy way to go and really didn't help that much). The easier/normal way of matching capacitors is to measure the case dimensions carefully and match up the voltage and uf (or mf) specs,
Oct 27, 2008 | Air Tools & Compressors
Craftsman 10" Table Saw Logo
675 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
