Question about Compex Computers & Internet
We had a power outage and the COmpex MX2216SB restarted flashing all lights and making a clicking noise I have tried turning power back off and on with no luck. Is there a reset button? Thanks
SOURCE: tv wont turn on only clicks and then flashes red timer light
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Posted on Nov 12, 2007
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
textonor
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Posted on Feb 11, 2008
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Posted on Aug 10, 2008
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
There was a power outage, and the red light on the printer keeps flashing but it won't print
Click on start and type services.msc and hit enter. Then scroll down till you see print spooler, right click it and say stop, count to 5 and right click it again and say run.
If this doesn't fix it try turning the power off on the printer and unplugging it and waiting 30 seconds then reverse the steps, plug back in and turn it back on.
Apr 04, 2014 | Dell 1130 Laser Printer
Clicking noise after power outage
If you had a clicking noise about once a minute for 3 to 5 times, then unit worked fine, you have no problem, it was just letting the pressure equalize in the system before the compressor could restart. (this happens if you had a very short power outage).
If you are getting many clicks and compressor is not starting, you will have to replace the motherboard.
May 27, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
My broadbank link flashing red
Hi
Flashing red light means system restarted due to power outage and or system was restarted, Wait for system to boot. The power adapter may not be connected firmly in the power socket or the wire connected at the back of your router may be loose.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
Red light flashes,10 sec after turning on. after power outage
Hi, thank you for visit fixya.
Do you need replace both stk 392-110, and check any resistor (2.2 ohms) for blown or open. You can replace this IC's for stk 392-150d9f769b.jpg
May 12, 2009 | Panasonic PT-53WX42 53" Rear Projection...
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
50 inch dlp wont restart after power outage
did you replace the light bulb from the back of the tv set ?
check if its blown ?
if so just replace and your good to go ....
Aug 07, 2008 | Toshiba 50HM66 52" Television
Tv wont turn on only clicks and then flashes red timer light
help!
trinitron kv29f1u
Jul 26, 2008 | Sony KV-35S42 35" TV
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Computers & Internet Logo
57 people viewed this question
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
