Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Black vetical line
There is a black vertical line left of center on the screen of a Hitachi plazma tv. When it was first noticed it would only be visable a short time and then disappear. Now it will appear soon after the set is turned on (within ten minutes or so) and does not disappear anylonger but remains there as long as the set is on. Is there any help for it?? Is it repairable? (by me??)
  • ernesto caim Jan 31, 2013
    Hi your problema its like it in attachment? 66% top to botton darkend with black vertical lines???? What solution for it?
  • 934 Answers
It's either x-main or logic board... Take it to a qualified shop and I think you'll be impressed... Most of these are repaired at module level now and it makes the repair relatively inexpensive.
Posted on Nov 19, 2007
Sharp Aquos LC-40C32U: Black screen, various vetical colored lines for extended period after turning tv on (volume button changes appearance of vertical lines)
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots do defective LCD panel are given. You can see and compare it to that of your TV's.
Apr 21, 2014 | Sharp Aquos LC-32D40U Television
Vertical black line on the left side of the
it means the lcd panel is failing you will need a new one at a appox cost or 1500 dollars it is covered under warr
Dec 20, 2009 | Televison & Video
Big Black Vertical line through the center of the screen
hi i have a big black vertical line going through my 42 in hyundi plasma what is wrong
Dec 15, 2009 | Hitachi Televison & Video
Black vetical lines on the screen. how do u fix
You need to flash or update your computer's bios. if you have an inspiron 1501 go here:
read the installation instructions or print it. then download the file and follow the instructions. after restart. see if you still get the vertical lines.
Mar 02, 2009 | Dell Inspiron E1505 Notebook
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
same problem 2 inch vertical line in center of screen! could this be something loose in the back??
Mar 13, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
222 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
