Question about Dremel 1800-01 Scroll Station 18" Variable Speed
Delta 18" VARIalbe speed scroll saw
Speed suddenly accelerated then decreased. Inspection revealed a broken 2" plastic or hard rubber circle is broken. It has a 7/8 "diameter center hole which appears to have been attached at the top of the eccentric drive Model no. 40-601 SN 430-03-651-001 bought new about 1990 but very few hours on it. Is part available as well as how to replace?
  • buntwort Nov 21, 2007
    My inquiry was for a DELTA scroll saw not Dremel.
Check out for parts
Posted on Jun 03, 2008
I need a manual for a Delta 40-500 15" hobby scroll saw
The closest I could find is the Delta 40-530 16".
Here is a parts diagram for Delta 40-500 type 1
Delta 40 500 Type 1 15 34 Scroll Saw Parts
Here is a parts diagram for Delta 40-500 type 2
Delta 40 500 Type 2 15 34 Scroll Saw Parts
Oct 09, 2016 | Saws
Manual for delta 40560 scroll saw
First you might try this link Delta 40 560 Type II Instruction Manual for a free download. I think there may be others.
Though not an instruction manual, this website Delta 40 560 Type 2 16 34 Scroll Saw Parts gives exploded diagrams of the saw.
Finally have a look at the Delta website and see if you can find a download there or ask for one.
Jan 19, 2016 | Delta Two Speed 16" Bench Top Scroll Saw,...
How to change a fuse on delta 20 inch variable speed scroll saw
there is a delta web site that gives you a down load manual if you don't already have one.
it shows you where the fuse is located on page 10 - fig. 10.
here is a link to the page
Jan 09, 2015 | Delta 40-690 20-in Variable Speed Scroll...
When suddenly giving full accelerator in honda activa, it is reducing the speed(decelerating) and again accelerating the speed. For example : i am going at a speed of 50Km , if giving the accelerator...
Sounds like you need to tune your carburetor and check the spark plug.
Try checking the CDi, replace it with an aftermarket racing CDi and compare the ignition and combustion, if it still doing that problem.
Tell us afterwards to guide you more of these problems.
Sep 13, 2011 | 2005 Honda Activa
How to install air hose on dw780 scroll saw
To get the plastic hose in:
Hammer in one or two of the plastic joints from the plastic hose with a rubber mallet to build the foundation to the metal connector.
Once you get the plastic foundation joints into the Dewalt Scroll Saw. It's easy to add rest of the plastic hose in.
Jan 24, 2011 | Dewalt DW788 Heavy Duty 20" Variable Speed...
My 16" craftsman scroll saw has a rubber tube that
The tube can be replaced with the plastic tubing used for aquarium air pumps that you can find in most pet stores. Unfortunately you have to disassemble the scroll saw arm to replace it. Remove the 6 screws at the back of the arm assembly, then the 4 bolts that hold the arm to the base. This will allow you to split the arm and you will find a plastic bellows that the hose connects to.
Nov 13, 2010 | Craftsman 16" Variable Speed Scroll Saw
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
Dremel 1800-01 Scroll Station 18" Variable Speed Logo
369 people viewed this question
Top Dremel Drills Experts
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
