Question about Refrigerators
Miele fridge too cold
We have a miele kd 6453 fridge freezer and it is too cold. Freezes everything even though we have it set as low as possible, (9 dergrees)
The back is covered in ice. We have tried defrosting a few times but after a day it is back to freezing.
Hi I have the same problem...did you find the solution?
Posted on Jul 12, 2010
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Jul 24, 2010 | Miele KFN8762SDED Bottom Freezer...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Everything freezes in bottom of refrigerator
Check that all seals are completely sealed, especially the freezer door. If the freezer door leaks, the bottom of fridge will constantly be cold. Also, check the flap in the inside back. It controls the air between freezer and fridge. It may be putting more air flow to fridge rather than freezer. The cold air will sink low and keep the drawer are colder.
May 05, 2009 | Whirlpool Refrigerators
Refrigerators Logo
430 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
