Question about Yamaha R-V702 5.1 Channels Receiver
Hello, simple question. I have a Yamaha R-V702
Hello, simple question. I have a Yamaha R-V702 5.1. I want to set up with just 2 main speakers and a centre speaker (3.1). Can you please advise the best way to set this up. I guess I just set up as for 5 speakers and turn the back volume down.
Regards,
Trevor.
    President:
  • 1,348 Answers
You are absolutely right
Posted on Jul 18, 2009
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Tip
How to connect an iPod to a speaker Yamaha Bar
<p>Yamaha speaker bar is a long, thin speaker system that is typically connected to a television because she can sit on the set. However, many people store their music libraries on iPods, and if you want one of those people you can connect your iPod directly to the Yamaha speaker bar. This is a fairly simple task that can be achieved in just a few moments. <br /> <p><br /> <p>1. Place the iPod in the iPod speaker dock from Yamaha as a bar, or connect your iPod through your door in the background that comes out the opposite. Depending on the model, the speaker dock or a bar directly above the control panel or a cable that runs from the back of the unit. <br /> <p><br /> <p>2. Power bar speaker Yamaha, do the same with your iPod. <br /> <p><br /> <p>3. Choose your music to play through the iPod screen. Press "Play" and you should listen to music through the speaker bar. <br />
on Aug 09, 2011 | Apple iPod touch
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Trying to hook up Zone B stereo speakers in two additional rooms.
The infrared mentioned by the manual is most likely an extension possibility to use the remote control in each room, forget that part.
What you need to do is quite simpel, after connecting all speakers, you should indicate in the setup menu of each zone which speakers are connected and do as follows:
in main room select 5.1 setup, for the other zone select only the left and right front speakers.
Your EXTRA SP indicates the extra speakers for 7.1 setup and when set to zone B it recognises only 1 speaker.
So read carefully the manual how to connect Zone 2 speakers and connect that way, than carefully walk through the setup menu to setup the zone 2 correctly.
Apr 09, 2009 | Yamaha RX-V663 Receiver
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Feb 22, 2009 | Yamaha RX-V1800
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
No Sound
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Aug 31, 2007 | Yamaha RX-V2090 Receiver
Yamaha R-V702 5.1 Channels Receiver Logo
120 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
