Dryers Logo
a
ann elias Posted on Aug 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my dryer a fire risk
Modelnumber tdc6a
Terry Hair
Level 3:
  • Master 4,134 Answers
  • Posted on Aug 01, 2016
Terry Hair
Master
Level 3:
Answers
4134
Questions
Helped
1091751
Points
16804
The recall covers a long period of manufacture, from April 2004 through September 2015. But there are only two types of dryers affected - Condenser and vented types.
Here are links to the Hotpoint (they make Proline) safety page that may help you to ascertain whether your model is one of the ones affected by the recall.
Safety Notice Tumble Dryers Safety Notice Tumble Dryers
Testimonial: "thank you you are arranging a engineer to call"
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 • Dryers
Not happy that my product is one effect
contact the manufacturer and ask for a refund on the machine
show proof of the document that it is a fire risk ( recall or alert document)
What're the capacities of Hotpoint dlb1550balwh dryer & wlw3500balwh cloths washer?
on all washing machine or dryer it most important is don't fill up it must have a space to the machine do the jobs ,
on the two machine 2/3 to 3/4 full is good ,
more your two machines are going to work incorrectly and broken !
and your dryer are going to overheat is bad for the dryer and a risk of fire all dryer have a overheating breaker but a risk of fire is a risk of fire,
be safe !
My proline tdc6a dryer isnt getting warm
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 26, 2010 • Dryers
2answers
I keep blowing my fuse
if the fuse is the right load for this dryer but keeps blowing then there is a sever fault in the dryer this could be in the wiring loom or more likely in the motor the dryer is pulling far to many amps and the fuse should then blow to protect the house wiring from catching "fire!"
yes i did say "fire!" so dont try up-rateing the fuse,,,,thats asking for it!
i would not use this dryer till you have it looked at,,,you will be risking a dryer or house fire if you do,,,
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 • Dryers
2answers
Dryer is making my clothes smell like smoke.
Clean out the dryer vent exhaust system. Check the gas burner for a clean blue flame with white tips. Air shutter on the gas burner may need adjusting.
Clean out any lint in the dryer cabinet.
Proline tdc6a taking 3 hours dry clothes
is it getting hot ? if not then its either the heating elements or thermostat. both available on espares. Most likely to be thermostats. If its heating then give the condensor a good clean. hope this helps.
Oct 29, 2008 • Dryers
Top Dryers Experts
john h
