Question about Garden
Pressure hose worn
I HAVE A SMALL 1200V 100BAR ALTO PRESSURE CLEANER.IT IS ABOUT 6 OR7 YEARS OLD. THE HOSE IS WORN AND NEEDS REPLACING. WHERE CAN I GET ONE??
  • 47 Answers
Ebay do plenty of replacement hose for the domestic and proffessional machines.
Posted on Jul 18, 2009
Can you suggest an alternative soft flexible hose for a Karcher power pressure washer 100bar
You need to ensure the Hose can handle the PRESSURE your machine is putting out. The Flexibility is a direct correlation to the requirement of the hose's ability to handle the pressure. Your 100 Bar is equal to 1460 psi. Depending on where you live, there are places that have Hose and Couplers and can make a Hose to your Specifications with the above information.
Mar 21, 2015 | Karcher Garden
Hose replacement or7
I fixed mine works good easy too watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
Sep 29, 2013 | Karcher K 5.85 M Electric Pressure Washer
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
I have good hose pressure but the head cleaner does not seem to move around the pool any more. I have checked for blockages etc> Could the head be worn out already? It is only 12 months old
The head on these pool cleaners should not be worn in only a year. It is probably another issue. Try this solution. Make sure that the diaphragm is not worn or damaged. This is most likely the problem if you have adequate flow, but the cleaner is not moving anymore. The diaphragm is easy and inexpensive to replace.
Jan 16, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
380 does not move, belts are ok
There are a lot of moving parts in these cleaners. They are simple if your familiar with them, but can be overwhelming if your not used to working on them. First of all make sure your pressure is good. pressure line could be clogged, pump impeller clogged, or inline filter (if there is one) can get clogged. Assuming pressure is ok, if you take the cleaner apart, there are bearings, and gears that can bind up if they're worn out. Also if the wheels and wheel mounts are worn the wheels can rub and effect the performance. This alone shouldn't stop it, but in combination with other worn parts it can. Obviously the belts worn out, broken, or if they're off will stop the cleaner but you said they are ok. There area number of small houses and slip ties that hold them inside the cleaner that distribute water where needed if the are broken come off, or leaking, that can stop the cleaner as well. How old is your cleaner? if it's more than a couple years (maybe even a year) there are several parts that can wear and need replacement. If the above information doesn't get you back on track. I suggest you take the cleaner into a local pool shop. They will be familiar with it, should inspect it and replace any parts you buy for free.
Sep 25, 2010 | Polaris 380 In Ground Pool Cleaner
Cleaner does not climb walls
First of all do you have enough suction? The cleaner originally should have come with a suction gauge. If not the local pool store will have one. How old is your cleaner? When the G3 and G4 cleaners gets over a year or two a number of things wear out and effect the performance. Inspect the diaphragm especially next to and under the small retaining ring and make sure there are no holes or tears. If the diaphragm is over a year old they sometimes get too spongy and effect performance. Also the small rubber pad that holds the large pad can get worn down and stick to the floor and wall. As parts wear down you can get play or slop between the large disc, the small pad, and the foot plate that snaps all the disc to the body. Also the rear cassette where the hose connects gets slop there as well. all of this slop, especially when combined can make the cleaner performance lack greatly. very common to have a cleaner not climb the walls or reach the far end of pool as it once did
Sep 12, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Inadequate pressure from my Alto pressure washer
Clean out spay head nozzle with small diameter wire and check that head is pulled or push in or out for high pressure.
Jul 28, 2009 | Garden
My Front load duet 6 years old will not spin.
is there water still in the drum?causing pressure switch to stay at high level(Iblocked drain or faulty pump),is the rubber hose (small )going to pressure switch blocked with gunge?with heavy usage for six years brushes on motor,could be worn(they are positioned 180degrees apart at one end of motor,--check those few things first before considering timer or motor contrl module,hope this helps
May 15, 2009 | General Electric WBVH5100HWW Front Load...
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
