Question about Intel Motherboard
No display on the screen and beep.
My motherboard is powering up and no video and post not running normal.No beep i can hear and i have swap memories and power supply even processors.
  • Mixplyxit Tigerbait May 11, 2010
    Did you just build this computer? Or did this just start happening one day?
  • 167 Answers
Hi, i am pretty sure this is a bios problem! but it could be video card or monitor. put it all back the way it was-when it worked-then reset the bios-unplug the pc-take out the battery.(about the size of a coin) there should be a three prong jumper, near the battery-and move it to the two prongs that has not had the jumper on it-then push the power button- this is to discharge the power that will be stored in any components on the motherboard- the pc is must be unpluged- then wait 60 seconds and put the jumper back and the battery(see if the battery is dead first) new ones are about 4 bucks, and they last a long time. then boot up the pc!-you should also set the bios at the correct values, as it will use default settings. some hp and others default settings are fine. on custom pc's setting values will need to be set for optimal settings, for the particular hardware. if this fails, try a new video card and check the monitor also. if you know the model # and brand, you can go to the website,then download the manual. this will show you the location of everything i told you to look for. if you need further help, reply. please rate this solution. good luck! one last thought motherboards can fail, from any number of things. hope this is not the case on yours.
Posted on Jul 22, 2009
  • Intel Master
  • 3,051 Answers
Hi there.
please try this unplug the computer, open the case and unplug the power supply to the motherboard. now remove the video card and ensure that it is clean than put it back in the slot that it came out of. next plug in the power supply back into the mother board and plug in the computer and try to power it up and see what hapens. hopefully esd was the cause of this common problem.
hope this works for you please keep me posted on this ok?
best regards mike
Posted on Jul 20, 2009
  • 62 Answers
Hi and welcome to Fixya!
this means the BIOS is corrupt in your motherboard ..you have to repair it in the service center
Thanks for using FixYa!
Posted on Jul 18, 2009
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
While i am power on then after laptop is giving beep and there is no display is coming
What is actually your problem, can you be more specific so we can try to help you...
Aug 19, 2011 | IBM ThinkPad Z60m Notebook
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
Computer beeps when I try to start up
No Beeps
1 Short Beep
2 Short Beep
Continuous Beep
Motherboard issue.
Three Long Beeps
Jan 05, 2009 | HP Computers & Internet
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Intel Motherboard Logo
321 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
