Question about SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Noy finding ip address senao wireless AP
Dear Sir,
When we connect senao ap directly to PC and we want find the IP address and MAc address of senao device , we cant find it so please give me the suggestion and so i can find the IP addres of following PC.
    President:
  • 1,566 Answers
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Posted on Jul 21, 2009
How i can change ip address of tp link 5210g throw ethernet cable
ok , need to assign your computer a Static IP address within the same
range as the AP's IP address, ip address of AP is : 192.168.1.254
the ip address for pc such: 192.168.1.253, then open your browser and write the ip address of your AP then you will be inside it .
Jan 10, 2014 | TP-LINK TPLink TLWA5210G 24GHz High Power...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
May 01, 2009 | Compex NetPassage 28G Wireless Router...
I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
SENAO NL-2611CB5 PLUS (NL2611CB5PLUS) Logo
807 people viewed this question
Top SENAO Computers & Internet Experts
Terry Hair
Vernon Taylor
Are you a SENAO Computer and Internet Expert? Answer questions, earn points and help others
