No cutoff ,inertia switch or reset --check fuses and relays also recheck pump and installation new doesnt mean free from defects or improper install
Very fee vehicles have a fuel pump shut off...this was a ford thing for a while. Nowadays fuel shutoff is accomplished by the various computers communicating in the car.
SOURCE: VW Golf Mk3 1997 diesel fuel pump replacement
1993–99 Cabrio, Golf, and Jetta
To install:
SOURCE: how to find and replace an 87 vw cabriolet fuel pump?
there is a pump in the tank ther is one under car.one in take is a pre pump one under car in black plastic housing .make sure fuel pump relay is working.
SOURCE: where is the fuel pump shutoff switch located on a 1996 chevy silverado 1500 located
Should be on the passenger side kickplate below the glovebox and to the right. You may have to remove the plastic panel to access it or look for a small hole in it and feel around for the button
SOURCE: Where is the fuel pump shutoff switch located on a 1996 chevy
may have a split hose in tank, makes a spashing noise
SOURCE: fuel shutoff switch switch location on a 1988 ford
The fuel pump inertia switch that shuts off the pump in the case of an accident or impact is located under the right side of dash I have also
found them behind the right kick panel. There is also a fuel pump
shutoff relay under the hood on the left firewall, and a relay on the
right fender apron behind a plastic cover. Hope this helps.
