Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
Setting up a wireless connection between my linlsys pcmcia card and my 2 wire gatway
How toset up a wireless connection between my linlsys pcmcia card and my 2 wire gatway
    Novelist:
  • 173 Answers
First insert your pcmci linksys card into the laptop, you would find a found new hard ware screen, insert the setup disk, and then follow the steps, automatically your card would be installed, once the installation is done, the wireless adapter , would detect wireless signal, try connecting to the wireless network.. if it asks for any key, look at the bottom of your 2 wire router you would find a 10 digit number, enter the number as the number as key code or password, automatically you would get connected.. if case if you have any problem , revert back ..
Posted on Nov 26, 2007
NEED TO CONNECT COMPUTER FOR WIRELESS ACCESS. DO I NEED A PC CARD OR A USB ADAPTER?
A USB adapter will work well.
if you have an available PCMCIA slot you could use that as well.
PCMCIA Slot: d_schrute.jpg
with a PCMCIA wireless adapter:
If the computer is a desktop and you have available PCI/PCI- Express ports you could get an internal wireless card like this:
Aug 20, 2011 | Computers & Internet
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
I have an older HP laptop with no wireless capability. We have DSL with the wireless router connected to our desktop. The only way I can access the internet is by putting in the AT&T air card. I don't want...
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Jan 17, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Toshiba satellite 2805-S301 laptop wireless card
Not wireless ready - as none of the 2805's were ever pre-wired with wireless card antennas. You can install a PCMCIA wireless card, or use a USB wireless adapter. Either one will work - the PCMCIA cards will be faster.
Dec 08, 2008 | Toshiba Satellite 2805-S301 Notebook
System: Compaq presario 2100 Intel. Disassembled the computer to fix the battery/power jack that is connected to the motherboard. My pcmcia/CISCO wireless card is not working since I fixed the computer,...
You can try using Compaq Diagnostics for Windows 95/98 for your model, there is no PCMCIA driver available on HP website for this computer.
If this is not a software problem, then it is probably a bad soldering joint that lost contact on one or more of the PCMCIA motherboard contacts.
Nov 29, 2008 | Compaq Presario Notebook
Fujitsu P1510 wireless card replacement
Some laptops have a modem or wireless card that clip onto the motherboard like how the RAM is fitted to the motherboard. This card is larger than the RAM and may have one or two wires connected to this card. If so you will be able to replace this card.
If the wireless is a chip and is mounted on the motherboard then it would be impossible to replace.
Your only solution to this problem is to buy a PCMCIA wireless card and insert into the laptop's PCMCIA slot or use a USB wireless device. You may have to go into the BIOS and disable the internal wireless device.
Nov 25, 2008 | Computers & Internet
PCMCIA
A PCMCIA Netword adapter/card will fit into this slot. This adapter is used for wired or Ethernet connection of the laptop to the network.
Hope this helps!
Nov 10, 2008 | Computers & Internet
Insatlling wireless in a samsung v20 laptop
Here are a few examples of the type nof card you'll need to connect wirelessly:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2030260034+1178314606&name=802.11b%2fg+PCMCIA+Wireless+Adapter
You can buy PC-Card (PCMCIA) wireless cards at most any computer electronics store/website.
Install the driver, insert the card, then configure the wireless connection.
Jul 10, 2008 | Computers & Internet
Network card
Any type of PCMCIA network card should work okay.
Go down to Staples, Best Buy or Office Depot and find
a decent PCMCIA network card.  You should be able to find
one for under $50
Mike
Oct 29, 2007 | Compaq Armada E500 Notebook
Using G630 but get "network cable unplugged" message
A little confusing this, it would not say 'Network cable unplugged' if windows was refering to your D-link wireless connection(It's wireless) The cable unplugged should be refering to your Wired Ethernet card, so there must be no cable connected at one or other end. You don't mention anything about what the wireless card is trying to connect to(eg Wireless modem/router or another wireless PC). Maybe your pc is getting confused as to whether you wish to connect wirelessly or wired, as it can only work through one IP Address at a time. i could be wrong, but you probably thought that they were working but only one was, you really need to explain why you are using both wired and wireless and what is connected to what, Please reply and hopefully it'll get sorted
Oct 26, 2006 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
189 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
