Question about Kettler Mondeo Elliptical Trainer
I have a Kettler Tarus excercise bike. The main screen is not working.The screen is very dim. The small screen is ok. Help.
  • g_vale1 Jul 18, 2009
    I've changed the battery cable, plus the connector cable into the LCD screen. When I switch on the small screen is fine. The large screen is very dim, but the charactors are outline in the back ground.
    I've also tapped the screen for a dry joint, but nothing happens.
  • 601 Answers
Hi..
Firstly check the battery or replace it.
If that doesn't work, slightly tap on the side of the screen and check if the screen get bright, if yes there is some loose connection that you can fix.
Else the LCD have to be replaced.
Let me know
Thanks
Smith
Posted on Jul 18, 2009
  • Shereena M Smillan
    Shereena M Smillan Jul 18, 2009
    Try increasing the contrast from the menu if that don't that work. the LCD is bad.
    You have to get it repaired.
    KETTLER'S Parts and Service Staff are available for you Monday thru Friday from 9:00 a.m. to 4:30 p.m. EST at 866-804-0440. All requests can be submitted by phone, fax 757-563-9273 and e-mail at parts@kettlerusa.com
    Check this link..
    http://www.kettlerusa.com/page13.html
    Let me know.
    Thanks
    Smith
I need a manual for kettler traveler
Touring Bikes Buy Commuter Bicycles Touring Bicycles More KETTLER USA Kettler USA online shopping for tricycles pedal tractors ellipticals... , Kettler USA online shopping for tricycles pedal tractors ellipticals... ,,If you are unable to find your product manual please contact KETTLER Parts:
Phone: 866.804.0440 Monday thru Friday 9:00 a.m. to 4:30 p.m. EST Fax: 757.563.9273 email: parts@kettlerusa.com
Mar 09, 2015 | Kettler Sport & Outdoor - Others
Power Supply
Try emailing the parts department at Kettler USA: Kettler USA online shopping for tricycles pedal tractors ellipticals...
I used to have to contact them when I repaired Kettlers at the bike shop.
Feb 25, 2014 | Kettler Ergo Racer GT Indoor Cycling Bike
What is the power supply for a kettler apollo exercise bike?
I have no reference for that bike but if was bought in U SA contact them @ KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com
Or www.kettler.co.uk Customer Services sales@kettler.co.uk
Tel: 01527 588995
AfterSales aftersales@kettler.co.uk
Tel: 01527 591901 - select Option 1
May 12, 2010 | Cycling
Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Nov 10, 2009 | Kettler Mondeo Elliptical Trainer
Unusal valve stem on the tire tubes how do I pump?
ok mate you have to go to a bike shop and buy a the newer tubes the one your daughter has is really old and they dont make them any more so just go to a bike shop and ask for a bike tube and then ther you go also if ya need any help putting it on just give us a bell. and dont forget to rate me .
Mar 28, 2009 | Kettler Scoot Training Bike
Kettler Mondeo Elliptical Trainer Logo
87 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Bill Eager
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
