Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
    Problem Solver:
  • 11 Answers
Pls.check the unit if does have a low and high preasure switch,posible the system is in the low preasure that switch to cut off the unit.check system preasure,if low preasure found,you need to recharge the system.
Posted on Nov 20, 2007
0 characters
3 Points
I have an Admiral side by side model LSD2615HEZ that is not cooling. I can hear the hum of the condenser, but do not hear fans kicking on when I turn the temp gauge from 0 to 9. I don't hear a click or...
Do you hear the thermostat control clicking off and on if so turn on set about half way and remove cover from back and see or hear if the compressor and motor are running if not you need to replace the starting components go to a appliance store and buy a 3 in 1 kit and follow the diagram for installation make sure you disconnect the power before working on it. good luck and please leave me feedback so I know it works.
Feb 04, 2015 | Admiral 26 cu. ft. Side-By-Side...
My Admiral LSD2615HEZ freezer is icing up? The freezer temperature setting is set between 4 & 5 and the water dispenser and ice maker are working properly. What might be the cause and what are the...
Check the water pan underneath, dump if necessary. Clean up any dust, etc. Reset to normal temp and do not open door for 24 hrs. If this doe not work check compressor / condensor
Aug 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
My admiral side by side refrigerator (model #: LSD2615HEZ) is making a buzzing noise that clicks on and off periodically. It sounds like it's trying to start something and then shorts out after about...
A relay starts the compressor with a higher voltage and then quickly kicks out
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
If you still have trouble Go Here:
Thank you for using fixya
Leo Ponder
Aug 15, 2011 | Admiral 26 cu. ft. Side-By-Side...
Admiral refridgerator model lsd2615hez is making a buzzing sound every 2 minutes. The buzzing sound lasts 20 seconds and everything in the freezer is melting. What could be causing this?
what you are hearing is the compresor trying to start . and can not so the over load is shutting down . and when it cools it will try again .. you need to replace the starting device on the compressor .cost about 80.00 parts .. most models . some are more. and the melting is caused by no comp runing .. this is a very common problem .. hope this helps mm feed back pls .
Feb 01, 2011 | Admiral 26 cu. ft. Side-By-Side...
Freezer not working and now fridge not you think its the thermosat? Its 2 yrs old, with the icemaker, watercooler
Two years is a short time for a failure of a compressor. So first of all you will need to check from the compressor, for gas pressure and then to the timer, the therrmostat and wiring. Put the set off for 8-10 hours and after making sure that no lines have been cut by any rodents , switch on. If the fridge/freezer regains the temperature then it is sure that your timer/ heater and auto defrost section could be faulty. So check one by one and confirm. If however there is no cooling then your compressor performance/ gas pressure could be a reason. So check this out and seek a good help if you need assistance to confirm before changing any part. Good day
Aug 03, 2010 | Admiral 26 cu. ft. Side-By-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Not cooling, fan making noise and now humming
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Oct 27, 2009 | Admiral Refrigerators
Admiral side by side fridge defrosted and no longer cooling
Replace the compressor start relay.
If this does not solve the problem you most likely have a bad compressor.
Your fridge may be under a 5 year compressor warranty.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
333 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
