Question about Dell Vostro 1400 Notebook
I have dell vostro 1400 laptop.when my latop charger is plugged in laptop is charged but as suddenly when i unplugged charger laptop is shutdown no battry is charged what is the problem?
  • Dell Master
  • 32,281 Answers
You have either a faulty/worn out battery or a faulty charging circuit.
Recharageable battery have a finite number of charge and discharge cycles and over the years the battery life gets shorter and shorter until it is worn out and won't charge any more.
If the battery is more than 2 years old then the battery is most likely worn out and needs to be replaced.
Posted on Jul 18, 2009
Dell laptop wont charge battery.
The Laptop charger or the charging point itself is bad or damaged. You'll need to try different charger to take your laptop to any nearest computer repair shop to have charging point repaired or replaced.
Oct 28, 2014 | Computers & Internet
Charger hang laptop
Check the voltVoltage too high and the laptop shuts down to protect itself, too low and it won't work.
If it states 19.5vplts, that's what it needs.
Nov 21, 2013 | Dell Vostro 1400 Notebook
Internal speakers do not works
Unplug Headphones. Open Control Panel, Sounds, select Speakers. Perhaps Headphones are set as default. The Dell Audio drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-1400 Do ALL your Windows and Dell updates, if you haven't already, after a install.
Feb 04, 2013 | Dell Vostro 1400 Notebook
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
Battery not connect charging
Unplug and plug the charging wire to the computer.Thank you.
Dec 24, 2010 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Replaced Vostro 1400 Battery is not charging
You might have a defective ac adapter or power related problem on the system board. Go to radio shack and see if they have a tester adapter (most have universal laptop power adapters and you can try in the store to see if this works). If same issue, most like a defective battery or defective system board.
Feb 15, 2010 | Dell Vostro 1400 Notebook
HI I have a dell Vostro 1510.There is a problem with my system since yesterday .when I have connected my latop to the cahrger My laptop swiched off .And I am never again able to restart it.Later observed...
dear,
did u check the charger itself...its important ...
if you have multimeter then unplug the charger from laptop and plug the mains from socket to th charger plug and check the output DC voltage..is it coming, if coming then is it constant or varing ...if varing then u have to check the charger inside by an expert...
if its ok then remove the battery of the laptop and plug the main to charger and charger to laptop and then check its performance by switching on laptop...if its work then battery issue....
Aug 03, 2009 | Dell Vostro 1510 Motherboard System Board...
Dell Laptop Charger, wont charge bat. but keeps computer running.
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
May 07, 2009 | Dell Vostro 1400 Notebook
Dell has cheap chargers, the wire snapped on the inside underneath the rubber. My ex boyfriends charger had the same thing happen. You need to buy a totally new charger .
Jan 21, 2009 | Dell Latitude D531 Laptop Computer PC...
Dell Vostro 1400 Notebook Logo
303 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
