SOURCE: my poulan pro 6.75 self-propel mower stalls frequently
Replace the coil. Remove the top cover so that you can see the flywheel. There will be a horseshoe shaped peice with the plug wire attatched to it along with a small whir plugged onto it. Remove the two screws holding it on and unplug small wire and disconnect plug wire. When you put the new one on place a business card between coil and flywheel, this will give you the proper spacing, reconnect small wire and plug wire, reassemble top covers and you are good to go.
SOURCE: Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
SOURCE: poulan push mower question
Check the engine manufacturers web site. You will need your engine number. .....You will find an on line diagram and part numbers for your engine. Also, Most Mower Parts stores have the same thing !
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
SOURCE: how to change oil in poulan pro 650 series model
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
