Question about Canon PIXMA MP190 All-In-One InkJet Printer
I can't load my drivers because the print spooler service won't start
  • 92 Answers
Hi ....
Windows stops few services as a security steps agains various threats but you can start the services maunally. Follow the below instructions to start the spooler services again:
1) Right click on my computer and click on Manage.
2) In the computer management window, click on the (+) sign next to "Services and Applications".
3) Select Services.
4) From the services list on the right, right click on "Print Spooler" and click on Start.
This will restart the spooler services and again and you will not face any problem installing the derivers.
Don't forget to vote if this helps ... Cheers :)
Posted on Jul 18, 2009
When i try to load winfax pro 10 i get message stop printer spooler?
to stop the print spooler do this . Start ---Run----type Services.msc, it will open the services box there find for print spooler , open it and slick Stop button to stop and start to start.
Aug 14, 2012 | Symantec WinFax Pro for PC
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
Only prints first job - can't delete from que
Please try this approach instead:
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
I can scan, but not printing
It could be that the Print Spooler service has stopped and won't let you print. Please follow the steps below to fix the problem:
  1. Browse to Start -> Run.Type in "NET STOP SPOOLER" (this will stop the print spooler service)
  3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
Also, make sure your printer driver is updated. Please visit the Lexmark website at http://bit.ly/kqUsN8 to download the printer driver. Execute the file to update your existing driver.
Jul 27, 2011 | Lexmark X7350 All-In-One InkJet Printer
It kep saying that the spooling is not working
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
Try to print again.
Jul 25, 2011 | Lexmark X2600 InkJet Printer
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
Go to START
Choose RUN
Type SERVICES.MSC
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Spooler serivice is stopped
Overview
This article describes two methods for restarting the Print Spooler service within Vista.
Method 1: Restart the service using the services console
  1. Click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  2. Right-click Print Spooler, and then click Stop.
  3. Right-click Print Spooler again, and click Start.
Method 2: Restart the service at a command prompt
  1. Click Start, All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. Type the following commands at the command prompt.
    net stop spooler [Press ENTER.]
    net start spooler [Press ENTER.]
    exit [Press ENTER.]
Apr 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
158 people viewed this question
old marine
old marine
