Question about Standard (CRT) Televisions
Magnavox 32" tv ms3252s431 shutting off
i have a 32" magnovox tv (chasis L01-1uac-7638) that has broklen down 3 times in 18 months. the tv is only 4 years old. the symptoms are always the same: first the volume bar will appear and sometimes lower the volume by itself. then the main tv menu will appear on its own and randomly move thru the menu. the 3rd stage is it will do all of this, then shut itself off. the final is all of the above, then shut off completely and won't power up, with a faint chirping sound in the back until unplugged. someone mentioned replacing the C2455 resistor, but i don't know much about electronics. can you offer any advice or parts to change? it's been repaired twice already at a large cost both times. thanks.
  • 1,694 Answers
Re: magnavox 32" tv ms3252s431 shutting off
Usually, the L01-1 chassis most common problem = weak
capacitors, such as C2455.Could be C2425......47mf/25v...
Check all caps around horiz drive xformer = an ESR meter
helps on this one + a skilled, experienced technician......T.
Posted on Nov 19, 2007
0 characters
3 Points
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
How do I shut off the Closed Caption feature?
Bluffy you should access the menue on your remote and be able to shut it off!
Feb 16, 2009 | Philips Magnavox 27MS343S 27" TV
Magnovox tv
I pushed the volume up and volume down button at the same time and this reset the tv.
Dec 10, 2008 | Philips Magnavox MT1905B 19" TV
Magnavox MS3252S431
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
Phillips/magnavox smart series
I have a Smart Series 32" Phillips-Magnovox TV I bought april '99. Around July 4 weekend 2008 it decided it just does not want to come on any more! Was working just fine before that...I can not find my manual. Any suggestions?
Mar 04, 2008 | Philips Magnavox 27MS343S 27" TV
Magnovox TV
On many of these (I am not familiar with this exact one) you push the volume up and down buttons on the set (not the remote) at the same time and hold them for a second or two. Try this. Philips has a customer help line that can help you as well, but expect a long wait and much irritation.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
TV turns on at odd hours by itself
GO to Magnavox Owners Manual---on the www.
Oct 04, 2007 | Philips Magnavox 27MS343S 27" TV
TV keeps shutting off
Since the set needs to be unplugged and plugged back in, the requlator circuit in the power supply may have a problem. The set is over a decade old and other things are going to start going wrong with it. Capacitors will dry up, solder joints will begin to crack and the picture tube will begin to get weaker. My suggestion is to invest in a new set, with a newer technology. Hope this helps.
Apr 07, 2007 | Philips Magnavox TS3260C 32" TV
Television takes 6-8 times to start up or turn on
Sounds like you may have cold solder connections. Call a pro to assist in this repair. Good Luck
Aug 03, 2006 | Philips Magnavox MS3252S 32" TV
Standard (CRT) Televisions Logo
791 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
