Question about Canon PIXMA iP3000 InkJet Photo Printer
Black print on paper does not work ,all colors print ok .but when it come to files printing black does not show and does not print
    Problem Solver:
  • 6 Answers
Clean your printer head.. may need to change the cartridge.
Posted on Jul 18, 2009
Printer is out of cyna color but only want to print black how to we override
You have to follow this steps:
1. Load paper in the tray.
2. On the File menu in your software application, click Print.
3. Make sure the printer you want to use is selected.
4. To change settings, click the button that opens the Properties dialog box. Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
5. Change the paper orientation on the Layout tab, and paper source, media type, paper size, and quality settings on the Paper/Quality tab. To print in black and white, click the Advanced button, and then change the Print in Grayscale option.
6. Click OK.
7. Click Print or OK to begin printing
Mar 16, 2015 | HP Officejet Pro 8600
Can you print just in black ink
Yes, you can do black-only printing. However, your printer may need the color cartridge present in the carrier to continue to function.
With your document open, click File -> Print. In the Print dialog box, click Properties, Preferences, Options, or Setup. In Paper Options, select Print in black and white and click OK. Click Ok again to print your document.
Apr 29, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
Apr 08, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Can not get printer to print in black and white
Hi, May be you printer had been set auto color. To set it manually, go to printer setup in your computer. Select you file you wish to print the click print. On pop up printer set up you should see Canon MP 210 series printer. Then Click properties, you can see now the printer options like media, quality, paper source, color, greysacle and priview. Click greyscale to get monochrome printing.click Ok and Ok again. You should get a black white ( BW) printing result. In addition, to duplicate the file to get hard copies from your printer press Black button before do copying to get non color hard copy.
Dec 07, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I have a pinnacle Pro 901. How do I print in black & white only?
Hello, try this: Start Menu, > Printers and Faxes> then right-click on your printer. Move the pointer down to 'Printing Preferences' and click the 'Advanced' tab. There you will (should!) see 'print in greyscale' . Select this then click 'Apply' then 'OK' at the bottom of the page.
Regards,
nicam49
Dec 01, 2010 | Lexmark X2250 All-In-One InkJet Printer
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Color prints not working
have you gone to file> page setup>printer>properties>paper/quality hope this helps regards Jim
Jan 22, 2009 | HP DeskJet 990cxi InkJet Printer
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
222 people viewed this question
old marine
old marine
