Question about Mtd 22" Yard Machine Push Mower
Mine revs up then slows down.
I wonder if using premium gas is the problem. My car uses premium and I just siphen for use in the mover.
  • 22 Answers
If the machine has a briggs and stratton engine with a primer next to the fuel cap?? your problem wil be the carby diaphram remove the tank and carby to replace the gasket and diaphram under the carby
Posted on Jul 20, 2009
Murray lawn mower
Sounds like a fuel problem. Clean the carb good using fine wire and be sure to clean all of the small passages. Fresh gas and a new new fuel line can do wonders.
Jul 11, 2014 | Garden
Car is cutting out when stopping or slowing down, revs are goin down
1 Check for vacuum leaks, 2 Check the EGR valve, on mine the large nut on the metal pipe had come loose. 3 Clean and re-gap (or replace) spark plugs seemed to help. Mine (2004) needed new EGR valve to fix.
Nov 22, 2013 | 2000 Ford Focus
Car starts slowing down and tries to stop
IF YOU HAVE BEEN USING PREMIUM GAS TRY A TANK OF MID GRADE OR LOWER.
Nov 16, 2013 | 1997 Chrysler Sebring
1989 zuma scooter runs all fine but!, when i take off revs will be low for about 3 seconds than will pick up n start goin quick than will drop again and will take ages to wind up to speed, any ideas? my...
stop using cheap gasoline. Run premium from Shell or Mobil. You will defiantly feel the difference. Your bike will thank you with years of enjoyment..ps never store for more than a couple weeks with gas in it..run it out of gas before storing than when you get it out and add fresh gas shell give you no problems starting because of a gummed up fuel system..good luck..
Sep 20, 2012 | 2005 Yamaha Zuma
1985 ford f150 starts, but dies if gas pedal is not pressed, no problem starting, but as soon as I put in neutral it dies . . . tries to keep running but dies
Could be as simple as a vacuum leak from old hoses.
The carb WILL become DAMAGED from ethanol fuel.
DO NOT use that in a vehicle that sits.
Some premium gas has no ethanol,find it and use only it.
A good engine an worth spending a little money on.
May 01, 2017 | 1985 Ford F150
Mini cooper 02 shudders on low revs
ohh you just need to run premium gas or you can probably just use mid grade orrr you can put in a fuel additive like stp. that will raise the octane and no more low rev hesitation.
May 03, 2011 | 2002 Mini Cooper
I have a rival casserole crockpot model number,3050 slowcooker, 260watts, I was wondering if I can use the stoneware part in my gas oven? Thank you vicki
Yes, you can use the stoneware in your gas oven. I am using mine right now in my Convection Oven baking at 400 degrees. I use mine quite often in the oven for baked beaks, then transfer to my Crockpot.
Apr 19, 2011 | Rival Crock Pots & Slow Cookers
Jaguar s-type restricted performance displayed
Its most likely the coils and spark plugs, sometimes caused by oil leaking from the valve cover gasket. The coils deteriorate over time from engine heat and need to be replaced at 90-100k
Local garages don't have the Jaguar diagnostics terminal and are unable to do more than find basic error codes with a reader. Its important to get this fixed because it's causing damage to your caltalytic converters. They are expensive.
Jun 23, 2009 | 2003 Jaguar S-Type
What kind of gas? Regular or Premuim?
Regular is fine. I have a 626 as well with manual and it says regular.
Jun 25, 2008 | 2001 Mazda 626
Mtd 22" Yard Machine Push Mower Logo
287 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
